Publishing to Omniverse
Mode |
Tool |
Tool set |
Publish to Omniverse
Omniverse Connector (Windows only)
Visualization |
To publish a 3D model to the Omniverse collaborative platform:
Click the tool and mode.
If you are not already logged in to the Omniverse platform, you are prompted to do so.
The Publish to Omniverse dialog box opens.
This dialog box also opens when you publish a new file for a live session; see Connecting to an Omniverse Live Session.
Set the parameters.
Parameter |
Description |
Folder browser |
Provides a hierarchical display of the directories in the current Nucleus server; to expand or collapse a directory, click the disclosure button. Click a directory folder to specify where to save the published file or to add a folder. The Nucleus server is specified in the Omniverse Connector Preferences dialog box; to change servers, exit this dialog box and change the selection there. |
File information browser |
Displays the folders, files, and file information in the directory selected in the folder browser |
New Folder |
Adds a folder to the directory selected in the Folder browser |
Path |
Displays the selected directory folder's path |
File Name |
Enter a name for the exported file |
Save As Type |
Select whether to export a project (project.usd file), or a standalone prop (.usd file). Prop files can be used as an asset in projects, for example as a basic repeating element used in a more comprehensive project file. |
Export USD Options |
Opens the Export USD Options dialog box. If needed, override the default settings from the Export tab of the Omniverse Connector Preferences dialog box; see Omniverse Connector preferences. |
Checkpoint Comment |
Opens the Checkpoint Comment dialog box, where you can add a comment, if desired. The comments display with revisions of the project in Omniverse. |
The 3D model is exported to the specified location on the Omniverse Nucleus server.
