Adding roof accessories
Command |
Path |
Create Roof |
AEC |
In the Vectorworks Architect product, attic, soffit, and fascia roof accessories can be inserted when a roof object is being created, or they can be added, modified, or deleted later on. If the roof is reshaped, the accessories are automatically regenerated to suit the new shape.
The accessories are part of the roof object. To modify or remove them later on, select the roof object, and change the accessory settings from the Object Info palette.
Roof accessories cannot be added to roof face objects. See Creating roof objects.
To add roof accessories:
With the appropriate walls selected, select the command.
The Create Roof dialog box opens.
Click Create Accessories.
The Create Roof Accessories dialog box opens.
Parameter |
Description |
Insert Attic |
Adds an attic to the roof |
Attic Settings |
Opens the Edit Attic Settings dialog box for specification of attic parameters |
Insert Soffit |
Adds a soffit to the roof |
Soffit Settings |
Opens the Edit Soffit Settings dialog box for specification of soffit parameters |
Insert Fascia |
Adds fascia to the roof |
Fascia Settings |
Opens the Edit Fascia Settings dialog box for specification of fascia parameters |
Select the accessories to be added to the roof object.
For each selected accessory, click the corresponding Settings button.
A dialog box opens with parameters for that accessory.
Enter accessory parameters as described in the following sections and click OK to return to the Create Roof Accessories dialog box.
Repeat steps 4 and 5 until all desired accessory parameters have been entered.
From the Create Roof Accessories dialog box, click OK to return to the Create Roof dialog box; click OK again to create the roof object with the selected accessories.
