Inserting a soffit
  The soffit accessory has a "pork chop" profile.
To add a soffit accessory to a roof:
From the Create Roof Accessories dialog box, select Insert Soffit, and click Soffit Settings. The Edit Soffit Settings dialog box opens to set the parameters.
             Parameter  |
             Description  |
             Recess  |
             Specifies the distance between the bottom edges of the roof rafters and the soffit  |
             Trim Depth  |
             Specifies the distance between the outer edges of the rafters and inside edge of the soffit  |
