Curve-based addition or subtraction
Mode |
Tool |
Tool set |
Shortcut |
Sub-Face
Push/Pull
3D Modeling |
Shift+R |
To add or subtract from a solid in Sub-Face mode:
Click the tool and mode.
Select the NURBS curve or group of NURBS curves that will be used to create the protrusion or cutout, and then select the solid.
The cursor changes to a double-headed arrow. When an open NURBS curve is coplanar with the solid face and also splits the face of the solid, each split section can be moved individually. Move the cursor to expand (Add mode) or decrease (Subtract mode) the solid volume. The cursor direction determines whether volume is added or subtracted. The distance of the protrusion or cutout can also be specified by entering a value in the Distance field on the floating Data bar. The new solid is previewed on the drawing.
In Subtract mode, the distance value can exceed the solid perimeter; the cutout operation is only performed on the selected solid.
Alternatively, use the Offset Edge tool to create the NURBS curve and immediately extrude or shell an adjacent face; see Direct modeling with the Offset Edge tool.
Click at the desired location to edit the solid.
