Required server passwords
User names and passwords are required.
Select Control > Set Up Web Access Account and set up the password as described in the Site protection System Menu.
Alternatively, click Reread/Restart Servers from the main Server Administration screen.
Alternatively, access to the RLM browser interface can be controlled from the password file named rlm.pw in the same folder where the rlm executable is located (normally, this is the Vectorworks Site Protection Server folder (Windows) or /Library/PrivilegedHelperTools/com.vectorworks.rlm folder (Mac)).
Password setup in the password file consists of the user name, followed by the password, and then the permitted privilege, separated by colons. If there is more than one permitted privilege, separate each by a comma.
username:password:remove, edit_options
Set up the password file for the users with empty passwords. Individual users will need to change them later in the browser interface. For example:
lauren::shutdown, remove
Assignable privileges are listed in the table below.
Privilege |
Description |
all |
Enables all of the privileges |
edit_meter |
Does not apply to this software |
edit_options |
Allows ISV options to be set |
edit_rlm_options |
Allows editing of license files and rlm server option files |
edit_xfer |
logfiles |
Enables the various log file functions for the Report log and Debug log (creating new log files, switching log files) |
remove |
Permits removal of a license from a client who is running the Vectorworks program, shutting the client down |
reread |
Allows license files to be reread/reloaded |
shutdown |
Allows license servers to be shut down |
status |
Permits the display of status and Debug log information about licenses |
In addition to assigning privileges to individual users in the password file, you can specify groups, machines, and IP addresses in the RLM options file and then apply the privileges listed in this table to those groups. For example:
EXCLUDE shutdown group architects
For more information, see Controlling RLM options.
