Site protection System Menu
The site protection System Menu provides access to commonly-required license administrator tasks.
   To access the site protection System Menu:
On Windows, right-click the icon in the Notification area of the task bar, at the bottom right corner of the computer screen. On Mac, click the icon at the top right of the computer screen on the menu bar.
The System Menu opens. Select a menu command.
System Menu command
Description
Vectorworks Site Protection
Open Web Interface
Launches the Main server administration screen browser interface (Windows users can also double-click on the System Menu icon).
Set Up Web Access Account
Access to the browser interface (for functions such as license administration) is controlled by setting up an account with a name and password through the browser; both are required.
If the RLM server does not detect a password, it will shut down.
This command opens the Set Up Web Account dialog box, to enter an account name (the default is admin).
After entering the account name specified at server installation, the browser interface opens. If you have not previously accessed it, you may need to log in again on the left side of the interface. Leave the password blank initially, and then click on the Change Password pane to set up your password.
Passwords are also required for users who access the server; see Required server passwords.
Uninstall
Uninstalls the Vectorworks Site Protection Server software
Control (___)
The Control menu displays "Running" when the Site Protection Server is active
Start
Starts the server when it has been stopped
Restart
Restarts the server by refreshing all settings and license files. This does not fully restart the entire RLM server or interrupt the client workflow.
Stop
Stops the server; restart it by clicking Start
License
Enter Activation Key
When the Site Protection Server software is enabled by activation key rather than by a dongle, enter the activation key that was issued to you to generate and enable the license file. The activation key is remembered; to update a license, simply open the dialog box and click OK to reactivate the license using the key.
Add License from File
Select a license file (.lic file)
Licenses
Displays the name of all current server license files; any license can be revoked if needed
Revoke
Revokes a previously activated server license, allowing the server software to run on a different computer.
Revoking a license causes the license server to restart, and disconnects any currently connected users.
Products
Lists the available product licenses and shows how many are currently in use for each product
Usage
View Usage History
Opens the Usage History dialog box, for viewing the usage statistics by product as described in Viewing usage history
View Debug Log
The Debug log contains settings, records all events that occur from the server startup, and other information about the server and its environment; it can provide useful hints when troubleshooting. See The Debug log for more information.
View Report Log
The Report log file is a text file with statistical data about the licenses available on the server. It contains historic information such as usage status for each product. See The Report log for more information.
Access Permissions
Opens the Access Permissions dialog box, for Configuring access permissions
About
Displays the current version of the Vectorworks Site Protection server and the RLM version
Help
Opens this help system
Quit
Closes the System Menu, but keeps the license server running unless you stop it as well
The same functionality, along with many less-frequently used functions, can also be accessed from the browser interface; see Site Protection Server administration from a browser. The browser interface is useful for remotely controlling the license server when needed.
   If there is a notification or a problem with the license server, the System Menu icon indicates that attention is required.
Monitoring and controlling the license server and licenses
Troubleshooting
