Design SuiteStair settings: 2D Graphics tab
The settings on the tab can be saved as a set and then loaded, replacing the current tab parameters.
Click the 2D Graphics tab to set the stair’s 2D appearance on lower and, if desired, upper floors. The lower floor is always the floor where the stair has been placed. Selecting display options for the upper floor is optional; the upper floor representation is usually on another layer, and can be specifically selected here. These parameters do not affect the 3D appearance of the stair.
Parameter
Description
2D Graphic Settings
Saves settings so they can quickly be applied again; see Using saved sets for stair settings
View
Determines the view to apply the parameters to the stair; depending on drawing settings like layer scale and the document preference Auto display detail levels for design layers, the detailed or schematic view status is displayed
Detailed
Applies the 2D graphic parameters to stairs in a detailed layer scale view
Schematic
Applies the 2D graphic parameters to stairs in a schematic scaled view
Accept for all views
Applies the 2D graphic parameters to stairs in all views (detailed and schematic)
Stair Break Settings
Sets the stair break parameters; select the stair break configuration, and then refine the display with the additional parameters
Break Elevation
Sets the Z-height (relative to Layer Z=0) for the stair break
Break Line Angle
Specifies the angle of the break line, measured from the leading edge of the tread/riser
Break Lines Separation
Sets the distance between the pair of parallel break lines, measured in page scale units
Break Line Extensions
Indicates how far to extend the break lines past the sides of the stair
Draw outlines at break
When selected, draws boundary outlines around the stair object
Show markers at break
When selected, adds start and end markers to the walk line above and below the stair break
End of Walk Line is:
Sets the end of the walk line at either the last tread before the stair break or directly at the break
2D Graphics Settings
Controls the display of the walk line, nosing, stringers, headroom outline, and railings in Top/Plan view only
Show handrail
Displays handrail (railing parameters are set on the Railings tab)
Show top rail
Displays the top rail of the handrail and/or guardrail
Show posts
Displays railing posts
Show railing above stair break
Displays the railing above the stair break
Show nosing/riser offset
Displays the stair nosing and riser offset
Show tread offset
Displays the left and right tread offset
Show top tread
Displays the top tread in Top/Plan view
Show headroom outline
Displays the headroom outline; specify the headroom height above the stair
Show stringers
Displays the stair stringers
Show stair body edges
Displays the stair body edges in Top/Plan view
Show stair structure at lower floor
Displays the stair structure on the lower floor in Top/Plan view
Show notch at lower floor connection
Displays the notch on the lower floor connection in Top/Plan view
Show notch at upper floor connection
Displays the notch on the upper floor connection in Top/Plan view
Cut Graphic (on Layer [layer name])
The stair always displays on the lower floor (the floor where it has been placed). If an existing stair is selected for editing, the stair’s layer displays. If editing stair preferences, the active layer displays.
Set the display of stair breaks, walk lines, arrow directions, and stair text.
Display Stair
Select the stair display configuration for the lower floor:
Plain (no break): Does not draw a stair break; the stair is drawn as set by the 2D attributes on the Graphic Attributes tab
Solid with Break: Draws a stair break; the stair is drawn as set by the 2D attributes and 2D Stair Break on the Graphic Attributes tab, but line styles remain solid
Below Break Only: Draws a stair break; all geometry above the stair break is hidden
Above Break Only: Draws a stair break; all geometry below the stair break is hidden
Break, Dashed Above: Draws a stair break; all line styles above the stair break are automatically dashed according to the settings on the Graphics Attributes tab
Break, Dashed Below: Draws a stair break; all line styles below the stair break are automatically dashed according to the settings on the Graphics Attributes tab
Dashed Above Only: Draws a stair break; all line styles above the stair break are automatically dashed according to the settings on the Graphics Attributes tab
Dashed Below Only: Draws a stair break; all line styles below the stair break are automatically dashed according to the settings on the Graphics Attributes tab
Walk line below/above stair break
When selected, draws a walk line below/above the stair break. For Plain (no break) Display Stair style, draws a walk line the full length of the stair. When a walk line is indicated, select whether to display a start and/or end marker on the ends of the walk line (to show markers at a break, Show Markers at Break must be enabled). Select Show markers only to hide the line for the walk line, displaying only the markers. Set the arrow direction. The marker style is set on the Graphic Attributes tab.
Draw entire break
For Below Break Only and Dashed Below Only, select whether to draw the top of the stair break line, in addition to the bottom of the stair break line (which is always shown)
Stair Data
Opens the Stair Data Settings dialog box, for setting the appearance of stair text on the lower floor (see Step 2)
Top Graphic
Displays the stair on the upper floor in both detailed and schematic views, and sets the display of stair breaks, walk lines, arrow directions, and stair text for the upper floor.
If the stair’s Top component is used for horizontal section viewports, the default location is at the top of the railings. For stairs without railings, the default location of the Top component is 20 cm above the total rise of the stair, but that location can be changed (see Relocating 2D components of symbol definitions and plug-in objects). If you change the height of the stair, the default location is reset to 20 cm above the total rise.
Upper floor stair configuration
The Display Stair, walk line, and Stair Data options function the same as for the lower floor
Break Offset
Adjusts the position of the stair break along the walk line. Enter a positive or negative offset to position the break without any gaps between upper and lower floors.
Include top graphic on upper floor
For Top/Plan view, displays a 2D top graphic of the stair on the selected upper floor layer; select to enable Layer
Layer
Specify the layer on which to display the upper floor representation of the stair. This selection affects both the detailed and schematic display of the stair on the upper floor. It is not related to the total rise stair height selection on the General or Geometry tab.
Preview
Displays a preview of the upper and lower floors of the 2D stair with the parameters applied
Click Stair Data for the lower, and optionally, the upper floor, to set the display of the 2D stair information text.
The Stair Data Settings dialog box opens. The stair configuration determines the number of available run or flight parameters. The appearance of stair data text is set on the Graphic Attributes tab.
Parameter
Description
Show Numbers of Risers
When selected, displays the riser numbers for the stair.
Specify the text position and offset for the flight and the step, and set the text rotation.
Position in flight
For straight stairs, indicate whether riser numbers display on the center, left, or right of the flight. For other stairs, indicate whether riser numbers display centered, or on the inner or outer side of the stair flight. The Offset value sets the distance between the riser numbers and the stair boundary.
Position in step
Sets the riser position centered on the step or at the start of the tread. The Offset value sets the distance between the riser numbers and the start of the tread, for numbers at the start of the tread only.
Rotation
Specifies the rotation of the riser numbers
Start numbering at
Enter the number of the first step; the numbering of the steps will begin at this number
Run
For each available run of stairs with multiple flights, select whether to include text for the arrow direction (Up or Down, depending on walk line direction), total rise, number of risers, average riser height, average tread depth, walk line length, and/or line break. As each item is selected for display, its code appears in the text box; text can also be typed between items. Select Line Break to add a carriage return between items. Set the angle of the text.
Note
For the entire stair, select whether to include text for the arrow direction (Up or Down, depending on walk line direction), total rise, number of risers, average riser height, average tread depth, and/or walk line length. As each item is selected for display, its code appears in the text box; text can also be typed between items. Select Line Break to add a carriage return between items. Set the angle of the text.
The position of the stair run and note text can be adjusted by moving its control point.
Stair settings: General tab
Stair settings: Geometry tab
Stair settings: Construction tab
Stair settings: Railings tab
Stair settings: Graphic Attributes tab
Saving a stair as a symbol
Setting minimum and maximum values for stair geometry
Stair properties
Transferring stair properties
Creating a stair
Reshaping stairs
