Design SuiteStair settings: Construction tab
The settings on the tab can be saved as a set and then loaded, replacing the current tab parameters.
Click the Construction tab to specify stair construction parameters. The parameters displayed depend on the selected construction configuration.
Parameter
Description
Applies to
Construction Settings
Saves settings so they can quickly be applied again; see Using saved sets for stair settings
All
View (Detailed View only)
Determines the view to apply the parameters to the stair; depending on drawing settings like layer scale and the document preference Auto display detail levels for design layers, the detailed or schematic view status is displayed
All
Detailed and medium
Applies the construction parameters to stairs in a detailed layer scale view
All
Schematic
Applies the construction parameters to stairs in a schematic scaled view
All
Accept for all views
Applies the construction parameters to stairs in all views (detailed and schematic)
All
Construction Configuration
Select the type of construction for the stair
All
Solid stair
Models the stair structure as single, monolithic geometry, but still includes treads and risers
All
Stringer underneath
Models the stair structure as stringers (carriages) underneath that support the treads and risers above them. Enter the number of stringers.
All stringers will have the same width and be distributed evenly. An alert displays if the stringers don't fit into the available space.
All
Stringer outside
Models the stair structure as two stringers (carriages) on either side of the stair which support the treads and risers above them
All
Concrete stair
Models the stair structure as monolithic, without separate treads or risers
All
Circular stair
For circular stair configurations, select to obtain circular stair construction parameters
All
All
Landing Thickness
Specifies the thickness of the stair landing, excluding any treads. The landing thickness plus the tread thickness is equal to the distance from the top of the tread to the bottom of the landing (solid stairs) or stringer (stringer underneath)
Stairs with a single landing
Landing Thickness 1
Specifies the thickness of the first stair landing, excluding any treads
Stairs with two landings
Landing Thickness 2
Specifies the thickness of the second stair landing, excluding any treads
Solid Structure Thickness
When selected, draws 3D geometry below the treads and risers representing the structural mass of the stair. Specify the distance from the rear face to the inside edge where the riser and tread meet.
Solid
Concrete
Tread Thickness
When selected, draws 3D stair tread geometry; specify the tread thickness
Solid
Stringer Underneath
Stringer Outside
Riser Thickness
When selected, draws 3D stair riser geometry; specify the riser thickness
Solid
Stringer Underneath
Stringer Outside
Nosing/Riser Offset
When selected, draws both 2D and 3D stair nosing geometry; set the distance that the nosing extends past the riser face over the preceding tread
All
Create top riser and nosing
For stairs with the Draw Top Tread option disabled on the Geometry tab, select whether to display the top riser and tread nosing in 3D views
All
Offset Right (or Inner Offset)
Offsets the stair body from the right/inner edge of the stair treads and riser by the distance specified; as determined by the stair width, configuration, and orientation
Solid
Stringer Underneath
Offset Left (or Outer Offset)
Offsets the stair body from the left/outer edge of the stair treads and riser by the distance specified; as determined by the stair width, configuration, and orientation
Solid
Stringer Underneath
Stringer Depth
Sets the stringer’s structural clear depth
Stringer Underneath
Stringer Outside
Stringer Width
Sets the thickness (width) of the stringer
Stringer Underneath
Stringer Outside
Stringer Offset
For stairs with one stringer, specifies the stringer’s offset distance from the center of the stair
Stringer Underneath
Tread/Stringer Offset
Sets the tread’s offset distance from the bottom of the stringer’s depth, as measured to the back, bottom edge of the tread
Stringer Outside
Stringer Extension at Stair Bottom
Specifies the distance that the stringer extends past the front edge of the starting (bottom) tread
Stringer Outside
Stringer Extension at Stair Top
Specifies the distance that the stringer extends past the front edge of the last (top) tread
Stringer Outside
Column
When selected, adds a central column
All, when stair configuration is Circular Stair
Custom Column Height
Specifies the central column height for spiral stairs
Custom Column Diameter
Specifies the central column diameter for spiral stairs
Outside Nosing
Sets the value for the tread nosing at the outside diameter of a circular stair
Circular stair, when stair configuration is also circular stair
Upper Floor Thickness
Wraps the 3D stair geometry at the top of the stair around the edge of the floor slab by the indicated distance, correctly terminating all parts related to the construction type.
The stair object does not clip or join other objects such as slabs. You must ensure a correct fit by setting appropriate parameter values.
All (for solid and concrete stairs, this parameter is on the Upper Floor Connection Detail dialog box)
Lower Floor Thickness
Wraps the 3D stair geometry at the bottom of the stair around the edge of the floor slab by the indicated distance, correctly terminating all parts related to the construction type. If set to 0 (zero) truncates the stair geometry so the bottom of the stair rests on top of the slab.
All (for solid and concrete stairs, this parameter is on the Lower Floor Connection Detail dialog box)
Upper/Lower Floor Connection Detail
Opens the Upper/Lower Floor Connection Detail dialog box to define the geometry and fit of the stair body with the adjacent floors.
Solid
Concrete
For a solid or concrete Construction Configuration, click Upper/Lower Floor Connection Detail to open the Upper Floor Connection Detail dialog box or Lower Floor Connection detail dialog box.
Upper floor connection details
Parameter
Description
Option
Select the appropriate option for your construction:
Notch Top cuts a notch from the top of the stair body.
Notch Bottom cuts a notch from the bottom of the stair body.
If Draw Top Tread is not selected on the Stair Settings Geometry pane, there are no options to select before setting values.
Values
The stair profile graphic changes to display the parameters appropriate for the selected Option. The dot at one end of each red line indicates the locked end of the line; the value is measured from that point.
Specify the various inset, thickness, and depth values. If the Notch Bottom option is selected, choose whether to calculate the bottom notch depth value automatically by Until Stair Body or to set a Custom Length.
Lower floor connection details
Parameter
Description
Option
Butt aligns the bottom face of the stair body with the lower floor and creates a flat front face
Butt with chamfer creates a chamfer at the intersection of the horizontal and sloped parts of the stair structure
Notch aligns the bottom of the stair body with the lower floor and extends the upper part of the stair body by a custom offset
Notch with chamfer creates a notch in the lower part of the stair structure and a chamfer at the intersection of the horizontal and sloped parts of the stair structure
Inset creates a horizontal bottom face of the stair body and aligns the front face with the first step
Values
The stair profile graphic changes to display the parameters appropriate for the selected Option. For an Option with a chamfer, select whether to specify the support depth or the chamfer. The dot at one end of each red line indicates the locked end of the line; the value is measured from that point.
Specify the various inset, thickness, and depth values. If the Inset option is selected, choose whether to calculate the support depth value automatically by Stair Body Thickness or to set a Custom Length.
Stair settings: General tab
Stair settings: Geometry tab
Stair settings: 2D Graphics tab
Stair settings: Railings tab
Stair settings: Graphic Attributes tab
Saving a stair as a symbol
Setting minimum and maximum values for stair geometry
Stair properties
Transferring stair properties
Creating a stair
Reshaping stairs
