Controlling the visibility of palettes and tabs
To control the visibility of palettes and of individual tabs on multiple-tab palettes, such as the Object Info palette:
Do one of the following:
Select Window > Palettes > [palette name] or [tab name] to toggle visibility on and off.
Right-click on the drawing area, and select Palettes > [palette name] or [tab name] from the document context menu to toggle visibility on and off.
The tabs associated with each multiple-tab palette are listed immediately beneath the palette name on the Palettes menu.
Toggle visibility of an entire palette on and off, or toggle individual tabs
To toggle the visibility of a tab within its palette, click the Utility menu on the palette's title bar and select the tab name from the menu.
A detached tab’s visibility toggle is available in the Utility menu of the temporary palette where it is located (see Detaching and returning palette tabs).
To restore a detached tab’s visibility and return it to its home palette, click the Utility menu on the palette's title bar and select Dock [tab name] here or Dock all tabs here. Dock all tabs here restores the visibility of all tabs in the palette family, whether previously detached or not.
