Design SuiteEye bolts
Mode
Tool
Tool set
Eye Bolt
Fasteners
The Eye Bolt tool and Eye Bolt - 3D tool share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
See Customizing definitions for built-in plug-in objects for instructions on establishing custom object sizes.
To place an eye bolt:
Click the tool and mode.
Parameter
Description
Size
Specify the eye bolt size in diameter/threads per inch (imperial) or diameter/thread pitch (metric)
Type
Specify the eye bolt type
Eye Inside Dia
Specify the eye bolt’s inside diameter
Length
Specify the length under the bolt head
Thread Length
Specify the thread length
Thread Style
(2D only)
Select the thread style; see Fastener object thread styles
View
(2D only)
Select the 2D view
Show Center Line
(2D only)
Draws the eye bolt with center lines
Show Threads
(3D only)
Draws the eye bolt with threads
Place Locus at Center
Draws the eye bolt with a center locus
Inserting fastener objects using the Fastener tool
