Arc length dimensioning
Tool |
Tool set |
Arc Length Dimension
Dims/Notes |
The Arc Length Dimension tool measures and dimensions the length of an arc anywhere along its circumference. The dimension can be shown with its witness lines perpendicular to a chord on the arc, or perpendicular to a line tangent to the arc. There are also modes to hide or show a graphic of an arc over the dimension measurement.
This tool works with arcs, polylines that include arc segments, arc-based 3D objects, and curved walls. It always creates the dimension on the same plane as the arc that is being dimensioned.
Mode |
Description |
Witness Lines Perpendicular to Chord
Dimensions the arc with witness lines that would be perpendicular to a chord drawn across the arc |
Witness Lines Perpendicular to Tangent
Dimensions the arc with witness lines that would be perpendicular to a line drawn tangent to the arc |
Arc Indicator Visible
Displays an arc graphic over the dimension measurement |
Arc Indicator Invisible
Uses a dimension measurement with no arc graphic |
Standard |
To change the dimension standard for new dimensions created in the document, select a standard from the list; select Custom Standards to create or manage custom dimensions (see Using custom dimension standards) |
Units |
Select the units to use for this tool, or create a custom unit; see Using custom units for dimensions |
To create an arc length dimension:
Click the tool and modes, and then select a Standard (dimension standard) and the Units.
Click to set the measurement start point.
Click to set the end of the measurement.
Move the cursor away from the object.
This specifies how far the dimension line is offset from the measured object.
Click to place the dimension line.
