Editing doors
Once a door has been created, there are multiple ways to edit it:
Reshape its dimensions or move it, using the Selection tool.
Interactively change the door's handing, or orientation in the wall, using the Selection tool.
Edit unstyled doors or the by instance parameters of a styled door in the Door Settings dialog box for a selected door. To access it, click Settings from the Object Info palette, double-click the door, or right-click on a door and select Edit from the context menu.
Edit unstyled doors or the by instance parameters of a styled door directly from the Object Info palette; some door properties are available only from the Object Info palette.
Replace the door style from the Object Info palette.
Edit the door style, which changes every instance in the file that uses that style.
