Architect or SpotlightEditing seating sections
Command
Path
Edit Boundary
Context menu
To change the boundary of the seating section:
Select the command.
The Object editing mode opens.
Edit the boundary vertices directly, and use other tools and commands including the Clip tool, the Trim tool, and the commands for Editing 2D object surfaces.
When you exit the object editing mode, select whether to refill the seating section when the boundary changes are made, or discard the changes.
Alternatively, use the Reshape tool to reshape the boundary (see Reshaping objects).
Some, but not all, parameters can be edited from both the Seating Section Settings dialog box and the Object Info palette. The fields in the Object Info palette are named similarly (but not always identically) to those in the Seating Section Settings dialog box, and roughly reflect the order in which settings are entered in the dialog box. The seating section parameters are described in Creating seating sections. Only the parameters that are different are described here.
Some parameter changes require the seating section to refill, removing any custom seating edits. An alert displays to confirm the parameter change.
Parameter
Description
Seating Type
Static display of the selected seating type; this parameter can be changed in the Seating Section Settings dialog box (see Seating section settings)
Always Redraw Section
Redraws the seating section for each change made in the Object Info palette; selecting this option may use significant computer resources and slow down operations. If this option is not selected, you can click Update to redraw the section as desired.
Display Boundary
Displays the seating section’s bounding box
Display Section Info
Select for a static display of the number of chairs/tables, the maximum/minimum tables/chairs per row, and the maximum number of rows; if deselected, the data do not show
Display Focus Line
Display the seating section’s focus line with three control points that make it easier to visualize and control the seating orientation, the angle/radius. The end point with no arrow controls the angle of straight seats or the radius of curved seats. The end point with an arrow controls the focus point of the seats. The center point is used to move the line.
Update
If Always Redraw Section is not selected, click to redraw the seating section
Settings
Opens the Seating Section Settings dialog box to edit and redraw the seating section (see Creating seating sections)
Edit Seating
Click for Custom editing individual seats
Classes
Opens the Seating section settings: Classes pane to edit the class assignments for the seating section elements; other panes of the dialog box are not available and the entire seating section is not redrawn
Vertex parameters
Edits the vertices of the path object that the seating section is based upon; see Editing vertex-based objects
Equipment Subparts
Lists the subparts that make up the object. These subparts are counted and reported separately in equipment and inventory lists.
The parameters must be selected for display for this type of object in Spotlight preferences: Inventory pane.
Equipment Virtual Parts
Virtual parts are associated with an object and are reported in equipment and inventory lists, but do not display in the drawing. After adding virtual parts, they are listed in the Object Info palette.
Edit Virtual Parts
Opens the Virtual Parts dialog box to add virtual parts to the object; see Managing virtual parts and independent virtual parts
Assign Sources
Opens the Assign Sources dialog box to assign the object and its subparts and virtual parts to an inventory source; see Assigning equipment to an inventory
Command
Path
Edit Seating
Context menu
To make final custom edits to individual seats or sets of seats:
Right-click on the seating section and select the command.
Alternatively, double-click on the seating section object, or click Edit Seating from the Object Info palette.
The Object editing mode opens. You can add or delete seats, change the angle of individual seats, or change the size of the floor.
When you exit the object editing mode, select whether to modify the boundary when the seating changes are made, or discard the changes.
Custom renumbering selected seats
Command
Path
Number Seats
Context menu
To custom renumber only selected seats within the seating section:
The Number Seats dialog box opens.
Specify the new seat and row number parameters.
Select individual seats in the order you wish to number them, and then click in an empty part of the drawing to end numbering.
