Checking IFC models with Solibri
Command |
Path |
Solibri Direct |
Tools |
If you have Solibri® Office installed, you can establish a two-way live connection between Vectorworks and Solibri Office, to streamline the model checking process. Solibri Office has advanced data validation and model checking capabilities, which are typically used during the coordination phase of a BIM project to ensure model and data quality. The model views in both applications stay in sync, so you can quickly find and correct errors, and verify the corrections.
To check an IFC model with Solibri Office:
Export the file to IFC.
With the Vectorworks file open, select the command.
The Solibri Direct dialog box opens.
Parameter |
Description |
Solibri Installation(s) |
Search |
Locates all installed versions of Solibri Office; the located versions populate the Locations list |
Browse |
If the search fails to locate all available Solibri Office versions, click Browse to manually select versions for inclusion in the Locations list |
Locations |
From the list, select the version to use for this connection. If a new version is installed, click Search or Browse to add it to the list. |
Connection |
Connect |
Launches the version of Solibri Office selected in the Locations list and completes the connection. If the file is saved with an established connection, the connection is saved with the file. |
Disconnect |
Ends the connection between Vectorworks and Solibri Office |
Options |
When the programs are disconnected, opens the Options dialog box, to set how to connect the programs. Enter the Port for the communication endpoint, select whether to Use https or http for communication, and click Test. When Test is clicked, Vectorworks sends GET/ping, GET/about, and GET/status requests to Solibri Office; the response displays in the list browser to confirm that the connection is established. |
Interaction |
Select the areas of interaction; this selection can be changed any time, without disconnecting and reconnecting to Solibri Office |
View changes |
Changes in the Vectorworks view and/or projection are immediately sent to Solibri Office, keeping the model views in sync. If not selected, the model is loaded in Solibri Office using the default Solibri view and camera settings, not the camera view and setting in Vectorworks. |
Object changes |
When an object is modified or deleted in Vectorworks, a partial model update is automatically sent to Solibri Office to update the object |
Selection changes |
When an object is selected in Vectorworks, it is automatically selected in Solibri Office. When multiple objects are selected in Vectorworks, the first object appears selected in Solibri Office; the entire selection comprises the contents of Solibri’s Selection Basket. When an object is selected in Solibri Office, it is automatically selected and navigated to in Vectorworks. When the Solibri Selection Basket is changed to contain only one object, that object is selected in Vectorworks, without changing the Vectorworks model's layer and/or class visibilities. |
Select the Solibri Office installation to use and click Connect. Solibri Office opens, with the IFC model loaded.
Check the model in Solibri Office as desired.
Navigate to and modify the objects as needed in the Vectorworks model; both models reflect the changes.
After all changes are completed, export the Vectorworks model to IFC for delivery.
