Creating an equipment summary for a hanging position
An equipment summary can be created for the instruments on an individual hanging position rather than for the entire drawing.
To create an equipment summary for a selected hanging position:
Select the hanging position.
From the Object Info palette, click Insert Position Summary.
A position summary is added next to the hanging position.
If a summary build list has never been specified in the file, a placeholder labeled Build List is placed instead, indicating that a build list has not yet been specified in the file and needs to be set.
The position summary uses the Summary Defaults parameters for a position, as set up in the equipment summary key settings, and the summary is filtered for the current hanging position. As lighting devices are added to the position, click Insert Position Summary to add the lighting devices to the end of the summary. To change specific equipment summary parameters, select the summary and edit the parameters in the Object Info palette as described in Creating an equipment summary key.
If you delete a hanging position, the associated equipment summary is also deleted.
