SpotlightCreating an equipment summary key
Tool
Tool set
Equipment Summary Key
Lighting
Statistics on the equipment used in the drawing help with event organization and production. Equipment summaries can be created for all equipment, including lighting devices, speakers, hoists, TVs, and more, and/or for lighting devices on specific hanging positions (see Creating an equipment summary for a hanging position). The summary is placed on the drawing for clients, vendors, or installation crews. The summary, which can be custom formatted, can show the symbol thumbnail and name, the number of each type of equipment in use, and the total counts, along with other parameters and information. You can add special elements like notes, column breaks, circuit summaries, and other items. Counting can be subtotaled to count parts, such as lighting device bodies and lenses. Symbols which have the same instrument type are counted together, allowing for alternate versions of a single type. The summary can compare its information to the inventory so that the designer can determine how much equipment remains in the inventory.
The insertion modes specify the location of the summary's insertion point. The insertion point can also be changed later in the summary's settings.
Mode
Description
Insertion Mode: Top Left Mode
Sets the insertion point as the top left corner of the equipment summary key's bounding box
Insertion Mode: Bottom Left Mode
Sets the insertion point as the bottom left corner of the equipment summary key's bounding box
Insertion Mode: Top Right Mode
Sets the insertion point as the top right corner of the equipment summary key's bounding box
Insertion Mode: Bottom Right Mode
Sets the insertion point as the bottom right corner of the equipment summary key's bounding box
Preferences
Sets the default parameters for the tool
The Equipment Summary Key dialog box, accessed from the Preferences button on the Tool bar, has two uses:
Sets the default layout and formatting parameters individually for Position and Equipment types of Summary Defaults. (You can change the layout for existing summaries from the Object Info palette.)
Specifies the equipment to display in the summary key. Use filters, categories, and the > and >> buttons to move the items to include into the Items and Elements to Display list.
Once placed, the key can be edited from the Object Info palette.
There are two ways to place an equipment summary key:
Click the tool to place the summary key in the drawing (on a design layer or sheet layer, or positioned on a title block)
From the Object Info palette of a selected hanging position, click Insert Position Summary. The layout settings for a Position (Summary Defaults parameter) are used. A filter automatically applies to the summary to limit the equipment to the items on the hanging position, and the Key Title is set to the hanging position name.
Multi-cell lighting devices must be set up in a specific way to function correctly in the equipment summary. Use a single master symbol that contains all the component parts nested within the main symbol. Add the master symbol to the inventory list. For multi-cell lighting devices to be counted properly in the equipment summary, the data such as instrument types and wattages associated with the nested symbols must match the components of the multi-cell lighting device.
You can create a dedicated symbol for use only in the key if, for instance, the symbol used in the file is too long to fit neatly. This dedicated symbol must also be added to the inventory, and its data must match the components used in the lighting device for correct reporting. This symbol can be accessed in the Unused Equipment Symbols selection of the Available Items and Elements list described in this section.
To create an equipment summary key:
Click the tool and insertion mode.
If you are placing a summary for a hanging position, see Creating an equipment summary for a hanging position.
Click Preferences to open the Equipment Summary Key dialog box.
Parameter
Description
Limits the display of available components according to the filter and other selections
Filter
Select a filter to limit the equipment displayed in the Available Items and Elements list
Manage Filters
Opens the Inventory Management Filters dialog box, to create filter sets for displaying equipment for selection. See Managing inventory filters.
Used equipment symbols
Lists all symbols that are currently in use in the file
Used plug-in objects
Lists all the objects that are currently in use in the file (plug-in objects display in green so they can be distinguished from the used symbols in the Items and Elements to Display list)
Unused equipment symbols
Lists all the symbols in the file that are in the Resource Manager, but not currently placed in the drawing (unused symbols display in blue so they can be distinguished from the used symbols in the Items and Elements to Display list)
Other elements
Lists summary and display elements which can be added to customize the summary; certain items require the specification of additional customization options after adding them to the Items and Elements to Display list.
Column break: Adds a new column to the summary; items added after the break indicator will be placed in the new column.
Column Headers: Adds a predefined header descriptor (symbol, description, and count) to each column.
Begin subtotal: Indicates the start of a subtotal count section for the quantities of each symbol.
End subtotal: Indicates the end of a subtotal count section; the subtotal value is placed at this location (after the word, Total).
If a subtotal cannot be calculated, nothing is displayed in the summary.
Header: Adds a section header. Specify the text of each header by clicking Options.
Divider: Places a horizontal separator across the column; the separator does not extend into the border padding area.
Full divider: Places a horizontal separator across the column; the separator extends to the border.
Note: Adds text that is aligned with the symbol text. Specify the text of each note by clicking Options.
Typical symbol: Places a selected symbol that is normally the reference symbol used for label legends. Click Options to select a specific symbol.
Color summary: Adds a summary of all the gel colors used, with color, gel size, and counts (select Show Swatch in the Equipment Summary Key dialog box or Object Info palette to include a color swatch).
Circuit summary: Adds a summary of the circuits in use (usually only included with hanging position summaries).
Position height: Displays the position height value, when the instrument summary is filtered by position. (When not filtered by position, or when position heights vary, the height value displays "Varies.")
Gobo summary: Adds a summary of the gobos in use with lighting devices
Lists the items that can be added to the summary; the available items depend on the selection in Available Items and Elements. Sort the symbols by clicking in the column header.
Adds one or more selected items from the Available Items and Elements list to the Items and Elements to Display list. The items are added to the row above the selected row, or to the end of the list if nothing is selected.
Alternatively, double-click to add the item.
Adds all the items displayed in the Available Items and Elements list to the Items and Elements to Display list
Removes one or more selected items from the Items and Elements to Display list.
Alternatively, double-click to remove the item (except for Other Elements).
Removes all the items from the Items and Elements to Display list
Lists all the components, in order, to include in the instrument summary.
From this list you can:
Change the order by clicking in the first column and dragging to the desired location.
Click on the No Rotation column of a selected symbol to prevent the symbol from automatically rotating in the summary thumbnail display.
Click on the Scale column of a selected symbol to select the scale value; this overrides the default scale set for all symbols in Item scale.
Click on the Alignment column to choose Left or Center alignment of the selected symbol.
If more than one line item is selected, the rotation, scale, and alignment applies to all highlighted line items.
Sort Symbols
Click to sort all the components, including Other Elements, in alphabetical order
Options
For certain Other Elements, opens a dialog box with options; for example, if you added a Header element, enter the header text.
Alternatively, double-click to edit the item.
Equipment Summary Key Layout Settings
Set up the desired layout settings for each type of summary default: Equipment or Positions (hanging position), selected from the Summary Defaults
Column Settings
Left Margin
Sets the distance from the left of the summary insertion point to the bounding box of the displayed symbol
Column Width
Sets the total width of each column, in document units
Text Distance
Sets the distance between the end of the bounding box to the text description
Name Width
Sets the maximum width of descriptive text before it wraps
Counts Width
Sets the maximum width of the count column
Column Spacing
Sets the distance between columns
Symbol Spacing
Specifies the vertical distance between symbols. Additional distance is automatically added if the symbol is larger than the spacing.
Bounding Border
Style
Select the style of border for the summary, or whether to omit the border
Separation
For the double border style, sets the distance between the lines
Padding
Sets the distance between the border's inner line and the items within the summary
Set Insertion Point
Specifies the location of the summary's insertion point; this can be helpful, for example, if you want to snap the summary to a title block border. All text and formatting parameters remain referenced to the upper left corner, regardless of the summary insertion point location.
Key Title
Show key title
Displays a title for the summary
Text
Specify the title text to display
Position
Select where to locate the summary title with respect to the border
Format Title Text/ Format Header Text/ Format Body Text
Specifies the text formatting for the title, header, and body text
Show Symbols
Includes a thumbnail graphic of each equipment symbol in the key
Auto rotate
Orients symbols automatically to minimize the amount of space required
Item scale
Scales symbols by the specified proportion; this allows the summary key to be placed on a sheet layer without displaying the symbols at 1:1 scale. The scale of individual symbols can be overridden with the Scale column within the Items and Elements to Display list.
Show GDTF mode
Displays the GDTF mode for lighting devices
Show wattages
Displays the power consumption information of a consumer. For lighting devices, appends "@ [wattage]" to the instrument type. A blank wattage or a wattage of 0 does not display.
Show weights
Displays the unit's weight or load information, as set in the default parameters of the symbol
Show counts
Displays a count value for each object type, as limited by the selected filter
Compare to inventory
Compares and displays the counts against the total number of units of each type as calculated in the inventory
Show color lst
Includes a list of colors used by lighting devices in the drawing, as limited by the selected filter
Show color swatches
When a color list is included, adds a color swatch for each color
Show gobo list
Lists all of the gobo patterns used by lighting devices in the drawing, as limited by the selected filter
Show circuit count
 Displays the number of circuits for lighting instruments on a hanging position
Summary Defaults
Select whether to specify the default settings for the summary when inserting it with the Summary Key tool (select Equipment) or from the Object Info palette of a hanging position (select Positions).
This option is not available from the Object Info palette after the summary has been placed.
Set up the layout parameters. The default parameter settings made here apply to summaries placed later in the file. Defaults for Positions and Equipment (selected in Summary Defaults) are saved separately and are in effect depending on how the summary is inserted. Taking the time to establish the defaults makes it much easier to insert summaries for hanging positions or for equipment in the drawing with the desired defaults already specified.
Select the items to include in the summary. You can add equipment symbols in use, other types of symbols (such as cables, speakers, soft goods, etc.), equipment symbols present in the file (but not currently in use), and formatting elements such as column headers, notes, and circuit summaries.
Filter the list of items to see in Available Items and Elements. Then click each type of item and move the desired elements to Items and Elements to Display. To change the order, click in the first column and drag the item to the desired position in the list, or click Sort Symbols to sort them alphabetically.
If you have included other elements that require formatting, select each one from the Items and Elements to Display list and click Options.
For headers, position height headers, or notes, enter the header or note text.
For a typical symbol, select the symbol to indicate labels (usually a label legend symbol, located within the Label Legend symbol folder)
For circuit summaries, the Circuit Summary Options dialog box opens to specify the circuit information to include in a hanging position summary. Specify the types of devices to count and how to count them, and enter the device amperage rating/voltage to obtain a report indicating the circuit type you will need for those devices.
Parameter
Description
Header
Enter the circuit summary header text
Count By
Select whether to count the circuits by channel, dimmer, or circuit number
Two-fer By
Select the method for counting two-fered circuits as one circuit.
None: Counts all circuits, including ganged circuits
Explicit: Counts only two-fer circuits that were created by the Ganging tool
Anywhere: Counts any two-fered circuits, including those created by the Ganging tool and any set of two or more lights that are on the same circuit
Amperage Ratings
Specify the amperage ratings for the lighting devices, separating multiple values with a semi-colon (for example, 20;50 indicates 20A and 50A). Amperage rating is determined by a combination of a device’s wattage and voltage.
Some examples include:
With a voltage of 120V and a lighting device with a 5000W rating, the lighting device would go into the 50A circuit.
With a voltage of 120V and a lighting device with a 500W rating, the lighting device would go into the 20A circuit.
With a voltage of 120V and three 1000W lighting devices two-fered together, the lighting devices would go into the 50A circuit with two 50A two-fers.
Voltage
Specify the circuit voltage
Device Types
Select the types of devices to count in the circuit summary; typically two or more summaries are included, combining selected device types and specific power requirements so that you know the amperage required per circuit for various device types
Click OK.
Click in the drawing to place the equipment summary. Click again to set the rotation.
The equipment summary parameters can be edited from the Object Info palette or by double-clicking on the equipment summary. However, the Summary Defaults option is not available since the summary already exists for lighting devices or hanging positions.
Click Build List to respecify items to include in the equipment summary.
When lighting devices in the drawing, hanging positions, inventory counts, or other factors have changed, click Refresh to update the equipment summary with the latest data.
