Editing landscape areas
To edit the landscape area, do any of the following:
Change the parameters from the Object Info palette or by clicking Landscape Area Settings from the Object Info palette (see Landscape area preferences).
Use the Attributes palette for existing unstyled landscape areas or for applicable "by instance" parameters
If plants that make up the landscape area change, they also change within the landscape area. Similarly, if a plant is edited from a landscape area worksheet (see Creating landscape area schedules), the plant object changes.
Reshape the landscape area by right-clicking on it and selecting Edit from the context menu; the Edit Landscape Area dialog box opens. Click Path. The Reshape tool is automatically activated, to reshape the object directly in the drawing.
The Add Surface, Clip Surface, Intersect Surface, and Combine Surface commands can be used on a landscape area. See Editing 2D object surfaces.
