Assigning room finishes
Apply room finishes to space objects to track requirements and costs. The information displays in worksheets, data tags, and the Room Finish Legend.
To assign finishes to a space object:
Select an existing space object.
In the Object Info palette, select Include on room finish schedule and then click Assign Room Finish.
The Assign Room Finishes dialog box opens.
Alternatively, click Settings to open the Space Settings dialog box, and select the Room Finishes pane.
Parameter |
Description |
Surfaces |
Floor, baseboard, ceiling, and wall surfaces are listed. The wall surfaces available depend on the Document Finish Mode setting in the Room Finish Manager dialog box; see Room Finish Manager. Select an item from the Surfaces list to view its finishes in the Surface Finishes list below. In the drawing, the selected surface is highlighted in red so that you can easily identify it. By Style: If you're creating or editing a space style, you can specify whether this surface's finishes are set by style or by instance. #: For an unstyled space using NESW Document Finish Mode, you can drag the marker in this column to move the wall to another group. For example, you might move a wall from North to East. Tag ID: If desired, enter an ID in this column to display on the room finish data tag. Use Finish From: Select a surface from this column to copy its finishes to this surface. |
Surface Finishes |
Allows you to set up to five finishes for the item selected in the Surfaces list. Click a row's Finish column and select a finish from the list of those available in the document. Enter a Coverage percentage to indicate how much of the surface will be covered with that finish. For example, a wall might have 100% gypsum board as its base finish, along with 65% paint and 35% wood paneling as its top finish. In NESW mode, enter wall finishes for the North, East, South, and West surfaces only. To reorder the list, drag the number in the # column up or down. To remove a finish, select <No finish> from the Finish column. |
Remarks |
Enter additional remarks about the finishes for this space as needed |
Room Finish Manager |
Opens a dialog box to customize the finish list; see Room Finish Manager |
Select the desired finishes for each part of the room. The information is associated with the selected space object.
Select the Create Report command to add a Room Finish Schedule to the drawing. Alternatively, from the Resource Manager, select Vectorworks Libraries\Defaults\Reports_Schedules\Architectural Reports.vwx. Drag the appropriate Room Finish Schedule worksheet to the drawing.
To add a legend for the Room Finish Schedule, use the Create Rm Finish Legend command.
