Design SuiteCreating railings
Tool
Workspace: Tool set
Railing
Railing tool
Design Suite, Architect, Landmark: Building Shell
Spotlight: Event
The Railing tool creates a railing either automatically along stairs or slabs, or manually along a specified path using standard polyline creation modes. The tool can create handrails, guardrails, or both.
Alternatively, create a 2D shape and then select the Create Objects from Shapes command (see Creating objects from shapes).
Mode
Description
Check mark
(Pick mode)
Places the selected railing style in the locations selected in Pick mode. Alternatively, double-click to complete the operation.
Pick
Defines the placement of the selected railing based on a set of selected stair flight, stair landing, or slab objects.
Turn on object snapping. See Snapping to an object.
Vertex
Draws the railing along a polyline path
Gravity
Fits the railing to objects as you draw in Vertex mode; places the polyline on the ground plane, and creates the railing object correctly on the object
Polyline creation options
For Vertex mode, selects the method for drawing the polyline upon which the railing is based; see Creating polylines
Railing Style
Opens the Resource Selector to select a resource
Preferences
Opens the Railing Preferences dialog box to set default parameters
To create a railing:
Click the tool and mode.
Do one of the following:
Click Railing Style on the Tool bar to select a resource from the Resource Selector.
Click Preferences to open the Railing Preferences dialog box and specify the tool’s default parameters.
The parameters can be edited later from the Object Info palette.
To draw the railing along a polyline path, click Vertex, and then click the polyline option to use.
To fit to objects beneath the railing while drawing in Vertex mode, enable Gravity mode.
To automatically create a railing along stairs or slabs, click Pick.
In Vertex mode, draw the object along a polyline path. Click to set the start point; each subsequent click ends the current segment and begins the next. If Gravity mode is enabled, draw the polyline along the object edge where railings are required. To complete the object, click the start point again (for a closed object), or double-click (for an open object).
Gravity mode is enabled while drawing a railing along the edges of a slab
 Gravity mode, when enabled, places vertices "down." If the bottom of a post is under a site model, Gravity mode will not move it up.
In Pick mode, move the cursor to highlight individual edges of stairs, stair landings, or slabs. When over the desired edge, click to select the edge; continue selecting edges that require railings. Once the correct edges have been picked, click the check mark on the Tool bar (or double-click). Railing sections created from contiguous edges are automatically joined into a single object.
An exterior railing style is applied to the outside of the flight of stairs
Edit the railing settings from the Object Info palette. Edit the railing geometry as described in Editing railings. Join railing objects together with the Railing Join tool; see Joining railings.
Railing settings
To apply consistent settings to railings, it's recommended to use a railing style. The Vectorworks resource libraries provide several styles, or you can create a custom style.
To create a style, use the Railing tool’s Preferences to set the parameters, and then create a style as described in Custom plug-in object styles without catalog options.
These settings are available in the following locations:
Railing Preferences dialog box (creating an object)
Object Info palette (editing an object)
Railing Style dialog box (editing a style)
If a railing style is selected, only parameters set by instance can be edited (see Concept: Plug-in object styles). Parameters available only on the Object Info palette are listed at the bottom of the table.
Parameter
Description
Use Style
From the Resource Selector, double-click a resource to activate it, or click Unstyled. If a styled object is converted to unstyled, the current values are retained, but all parameters are set to By Instance to allow editing.
By Style/Instance
A graphic indicates whether each parameter is set to By Style and given a fixed value or set to By Instance and editable in the dialog box. An object style may have a combination of both settings, to balance the need for consistency and flexibility.
By Style/Instance settings are established by the style and cannot be changed from the settings dialog box.
To edit the object style, see Editing plug-in object styles; editing the style modifies all plug-in objects in the file that use the style.
Preview
The right pane of the dialog box displays a preview of the railing in the selected View and Render mode, along the distance specified in Length of Preview
Object Info palette options only
Style
Replace, edit, or remove the current style, or (for unstyled objects only) create a new plug-in style (see Custom plug-in object styles without catalog options).
Editing a style changes all instances in the file that use the style.
Hide style parameters
Hides the parameters that are set by style; these cannot be edited from the Object Info palette
Settings
Opens the Railing Settings dialog box
Flip Offset
If you entered a distance in Offset Railing from Path on the General pane or in the Object Info palette, switches the offset to the other side of the path
Railing settings: General pane
Parameter
Description
Draw Handrail/Guardrail
Select whether to draw the guardrail or handrail only, or both
Draw frame and infill
For guardrails, draws the frame and infill sections between the posts; deselect the option for a simplified view during the design phase
Draw 3D
Displays the railing in 3D views. Hide the railing in 3D, or display it with full detail. A large set of railings drawn in 3D can impact performance.
Enter the distance to offset the railing object (handrail and guardrail) from the drawn path. To switch the offset to the other side of the path, click Flip Offset from the Object Info palette
Railing settings: Handrail-Top Rail pane
Parameter
Description
Handrail Offset
Specifies the distance to offset the handrail from the railing object
Handrail Height
Enter the height of the handrail
Top Rail Profile
Opens the Resource Selector to select a top rail profile
Top Rail Width/ Top Rail Depth
Enter the dimensions of the top rail
Railing settings: Handrail-Bracket pane
Parameter
Description
Use bracket
Adds brackets to support the handrail
Bracket Shape
Opens the Resource Selector to select a bracket profile
Bracket Profile Width/ Bracket Profile Depth/ Bracket Height
Enter the bracket profile dimensions and the height of the bracket from the centerline of the handrail top rail
Spacing Type
Select how to space the brackets.
If there's a guardrail, the number and spacing of brackets is controlled by the guardrail post settings.
Spacing Distance
Enter the distance for Fixed Distance (the value represents the specific distance) or Equal Spacing (the value represents the maximum value) Spacing Type
Number of Brackets
When Fixed Number of Supports is selected in Spacing Type, enter the number of brackets to place
Show bracket in 2D view
Displays the brackets in Top/Plan view
Railing settings: Handrail-Termination pane
Specify how the handrail terminates at both the start and end of the railing.
Parameter
Description
Start Termination/ End Termination
Select a horizontal or extended type of termination, or no termination
Start Extension/
End Extension
Enter the extension length
Start Return Offset/
End Return Offset
(Return extensions)
Enter the offset distance from the start/end of the top rail
Start Self-Return Height/ End Self-Return Height
(Return to Self extensions)
For self return terminations, enter the height of the self return
Railing settings: Guardrail-Top Rail pane
Parameter
Description
Guardrail Offset
Specify the distance to offset the top of the guardrail from the railing object
Guardrail Height
Enter the height of the guardrail
Use top rail
Adds a top rail to the guardrail
Top Rail Profile
Use miter at start
Uses a miter at the start of the top rail; set the Start Miter Angle
Use miter at end
Uses a miter at the end of the top rail; set the End Miter Angle
Top Rail Boundaries
Select whether the rail should extend along the the entire path or end at the first and last post
Railing settings: Guardrail-Post pane
Parameter
Description
Post Type
Select the type of guardrail post
Inset
(Fascia Post)
Enter the inset distance for the fascia
Bottom Inset
(Fascia Post)
Enter the bottom inset distance for the fascia post
Post Shape
Opens the Resource Selector to select a post profile
Post Width/ Post Depth
Enter the post dimensions
Use post at start
Adds a post at the beginning of the guardrail; if desired, enter an offset distance from the end of the guardrail in Post Offset at Start
Use post at end
Adds a post at the end of the guardrail; if desired, enter an offset distance from the end of the guardrail in Post Offset at End
Spacing Type
Select the method of spacing the guardrail posts
Spacing Distance
Number of Posts
When Fixed Number of Supports is selected in Spacing Type, enter the number of posts to place
Show post in 2D view
Displays the posts in Top/Plan view
Railing settings: Guardrail-Frame pane
Parameter
Description
Offset Frame
Specify the distance to offset the frame from the railing object
Frame Boundaries
Select whether the frame ends at the railing end or the post end; this is useful when the post is offset from the start or end
Distance to Top Rail
Enter the distance between the top of the frame and the top rail
Distance to Floor/Nosing
Enter the distance between the bottom of the frame and the floor or nosing
Distance to Posts
Enter the distance from the sides of the frame to each post
Bars at top edge/ Bars at bottom edge/ Bars at left/right edge
Select whether to include bars along the edges of the frame
Bar Profile
Select a shape for the bars
Bar Thickness/Depth
Enter the bar dimensions for profiles other than Line
Railing settings: Guardrail-Infill pane
Select bars or a panel type of infill; the selection determines which parameters are available.
Parameter
Description
Infill Type
Select an infill made of bars (vertical and/or horizontal bars) or a panel type of infill
Offset Infill
Specify the distance to offset the infill bars or the infill panel relative to the frame; because the distance is relative to the frame, if the frame offset changes, the infill moves along with it. Setting an offset for the infill is useful for aligning the infill to be flush with the frame on the left or right side.
Bars parameters
Evenly spaced with top and bottom edges
Spaces the bars at an even distance to the top and bottom edges; deselect this option to specify varying distances
Distance to Top Edge/Distance to Bottom Edge
When the bars are not evenly spaced with the top and bottom edges, specifies the individual distances to each edge
Evenly spaced with left and right edges
Spaces the bars evenly within the frame; deselect this option to specify a different distance from the left and right edges of the frame
Distance to Left/Right Edge
When the bars are not evenly spaced within the frame, specifies the distance from the left and right edge
Use vertical bars
Adds vertical bars to the frame; enter the distance between the bars in Vertical Bar Spacing
Use horizontal bars
Adds horizontal bars to the frame; enter the distance between the bars in Horizontal Bar Spacing
Rotate bars to diagonal
For straight railing sections, rotates the bars
Bar Profile
Bar Thickness/ Bar Depth
Panel parameters
Specifies the distance of the panel to the top and the bottom edge of the frame
Specifies the distance of the panel to the left/right edge of the frame
Panel Thickness
Enter the panel thickness
Railing settings: Corners pane
Parameter
Description
Support at corners
Adds supports for infill frames or panels at railing corners
Use double supports
Adds supports for each side of the corner; enter the distance for each support from the corner in Distance from Corners
Corner Angle Alignment
Specify how to align the corner post with the railing.
Align to Previous Edge: Aligns to the railing segment that comes before the corner
Align to Following Edge: Aligns to the railing segment that comes after the corner
Align to Corner Bisector: Aligns to an angle that divides the two segments
Use infill at corners
Extends the infill to the corners of the railing
Railing settings: Attributes pane
Parameter
Description
Attributes
Lists all geometry that has graphic attributes settings. The class and graphic attributes of each part of the object are displayed.
Double-click a line in the list browser, to set attributes for the part, and do any of the following:
To control appearance and visibility, select a class from the list of classes present in the drawing, or create a new class. Select <Railing Class> to place the part in the same class as the railing object.
To specify a material for a 3D part, select one from the Resource Selector; the material provides the fill and texture, though the texture can be overridden.
Set the attributes; see The Attributes palette.
To specify a texture for a 3D part, select a texture from the Resource Selector, or click one of the buttons to use no texture, to use the class texture, or if the material's texture was previously overridden, to revert to the material's texture. Set the map type and rotation as needed; see Concept: Texture projection and orientation.
For textures on a 3D part, select Randomize offsets to apply a random horizontal/vertical offset to each instance of a subpart, resulting in a natural, random texture appearance.
For textures on a 3D part, select Follow longest edge to orient the texture along the longest edge of the part. This can prevent the texture on a post or rail from being flipped in a wrong direction that doesn't match the post orientation.
Make All Attributes by Class
Sets all material, fill, pen, line type, line thickness, and texture attributes by class
Remove All by Class Settings
Removes all by class settings for material, fill, pen, line type, line thickness, and texture attributes
Editing railings
Joining railings
