Transferring stair properties
Mode |
Tool |
Workspace: Tool set |
Pick Up
Stair
Design Suite, Architect, Landmark: Building Shell Spotlight: Add tool to workspace |
Specific stair parameters can be transferred from one stair to another.
To transfer stair attributes:
Click the tool and mode.
Click Preferences to set the transfer parameters in the Stair Settings dialog box.
The transfer attributes are not available by clicking Settings from the Object Info palette.
Click the Transfer tab.
Parameter |
Description |
Attributes |
Select the stair attributes to transfer; selected attributes display with a check mark |
All/None |
Selects/deselects all the attributes with a single click |
Picked up values become stair defaults |
When the selected attributes are picked up in Pick Up mode, they also become the default parameters for the Stair tool |
Accept for all Stairs in Drawing |
The most recently picked up, selected attributes, are applied to all stairs in the file |
Select the attributes to transfer, and select whether the attributes should become Stair tool defaults and/or should also apply to all stairs in the file.
In Pick Up mode, click the stair with the desired attributes.
The cursor changes to an eyedropper, and the source stair is highlighted in red.
Move the cursor to the target stair, and click Apply mode from the Tool bar.
Press the Option (Mac) or Ctrl (Windows) key to switch between the Pick Up and Apply modes.
Click the target stair to transfer the selected attributes.
