Design SuiteCombining curtain wall frames
Mode
Tool
Tool set
Combine Frames
Combine Frames mode
Edit Wall
Edit Wall tool
Building Shell
To combine curtain wall frames:
Click the tool and mode.
Select the curtain wall to edit.
Click the two frames to be combined. Frames must be collinear.
At a four-way frame intersection, it may be necessary to split a perpendicular frame to be able to join collinear frames.
One frame is created. The attributes of the first clicked frame apply to both frames once they are combined.
Combine Frames Steps
Editing curtain wall frames and panels
