The Select Function dialog box
The Select Function dialog box adds functions or fields to formulas in a worksheet or data tag, or to a condition or field mapping in the Data Manager.
From the Select from list on the left, select the general type of data to work with: records, functions, or styles. In a worksheet or data tag, if Vectorworks Design Suite is installed, you can also select from data sheets, and IFC or COBie data. Then from the list on the right, select a more specific category within that data type; to filter a long list, enter text in the search field above the list.
The options available in the Function/Field pane depend on the selections in the Select from lists. To filter a long list, enter text in the search field above the Function/Field pane.
Select a function or field from the list and click OK to add it to the formula.
