SpotlightCreating custom electrical devices
Tool
Tool set
Electrical Component
Cable/Power Planning
The Electrical Component tool and the Distributor tool share the same position in the Cable/Power Planning tool set in the Spotlight workspace. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
Electrical component objects are plug-in objects that define the internal components of an electrical device. They determine what type of connections the device can make so it can be power patched correctly within the electrical system. There are five types of electrical components: power sources, inputs, overcurrent protectors, outputs, and consumers. By using the Electrical Component tool to place component objects within a symbol definition, advanced users can create a custom electrical device that participates in power calculations.
Custom distributor symbol with five output components
Electrical component objects define the internal wiring of an electrical device, which determines how the device symbol connects to other devices. Place electrical components inside the device symbol definition at the specific connection points. The visibility of the components is controlled by the Power class.
When a symbol contains an electrical component object, Power Information parameters display on the symbol's Object Info palette to enable power patching; see Power patching from the Object Info palette for more information. The order of the input and output fields is determined by the electrical components' stacking order; see Changing object stacking order. The distributor and lighting device symbols in the Vectorworks libraries are pre-defined electrical devices, so they display Power Information parameters by default.
Pay special attention when naming an electrical component. This name identifies the component in the container device's Object Info palette and in the power schematic (see Concept: Power schematics). If a name is not provided, a generic name is assigned with an incrementing number. For example, if a distributor with an ID of DistroA has two output sockets, the device symbol requires two output components. By default, these will be named Output and Output 1. The components will display as DistroA.Output and DistroA.Output1 in the power schematic.
Mode
Description
Power Source
Places a power source electrical component
Input
Places an input electrical component
Overcurrent
Places an overcurrent protector electrical component
Output
Places an output electrical component
Consumer
Places a consumer electrical component
Placing a power source component
Mode
Tool
Tool set
Power Source
A power source component enables a device to generate power.
When a power source component is placed in a custom electrical device symbol, it generates an output field on the Object Info palette of the device. When power patching the device, this output can be connected to another device's input; multiple connections can be made. See Power patching from the Object Info palette and Concept: Power schematics.
The power source component cannot be power patched from its Object Info palette.
To place a power source component in a symbol definition:
Select a symbol instance in the drawing, and select Edit 3D Component from the context menu.
Alternatively, right-click on the symbol in the Resource Manager, and select Edit 3D Component from the context menu.
The symbol's 3D component displays in Object editing mode.
Click the tool and mode.
Place the component in the desired location.
Set the parameters on the Object Info palette.
Parameter
Description
Rotation
Rotates the component
Name
Enter a name for the component. This name is globally used for power patching, with the container device's ID prepended. For example, Distrib1.GeneratorOut1.
Scale X/Y/Z
Scales the component geometry. The default size is 10 cm x 10 cm x 10 cm.
2D Part X/Y
Sets the X/Y coordinate position of the component's 2D geometry
Connector
Select the connector for the component
Maximum Power
Displays the maximum power in amps per phase of the power source
Voltage
Displays the voltage per phase of the power source
Click Exit Symbol to return to the drawing. An output field displays on the Object Info palette of the symbol, which now functions as a patchable electrical device. The output field is labeled with the component Name.
Placing an input component
Mode
Tool
Tool set
Electrical Input
An input component enables a device to receive power.
When an input component is placed in a custom electrical device symbol, it generates an Input field on the Object Info palette of the device. When power patching the device, this input can be connected to another device's output; a single connection can be made.
The input component can also be power patched from its Object Info palette. Each socket of the input component can be connected to an output socket or an overcurrent protector in-socket; multiple connections can be made. See Power patching from the Object Info palette and Concept: Power schematics.
To place an input component in a symbol definition:
Parameter
Description
Rotation
Name
Enter a name for the component. This name is globally used for power patching, with the container device's ID prepended. For example, Breakout1.Input1.
Scale X/Y/Z
2D Part X/Y
Connector
Select the connector for the component. The selection determines which socket fields display below.
Sockets
Select each socket connection from the list of Available options, defined by the Connector. Enter text in the search box to filter the list. Selected options are listed under Connected.
If two or more options are selected, <Multiple Connections> displays on the Object Info palette.
Click Exit Symbol to return to the drawing. An input field displays on the Object Info palette of the symbol, which now functions as a patchable electrical device. The input field is labeled with the component Name.
Placing an overcurrent protector component
Mode
Tool
Tool set
Overcurrent
An overcurrent protector component defines the breakers (of the type MCB: miniature circuit breakers) that limit the current running through the wires of a device.
The overcurrent protector component can be power patched from its Object Info palette. The sockets of an overcurrent protector component can be connected to an output socket or an input socket; multiple connections can be made. See Power patching from the Object Info palette and Concept: Power schematics.
An overcurrent protector component does not enable connections from the container device's Object Info palette.
To place an overcurrent protector component in a symbol definition:
Parameter
Description
Rotation
Name
Enter a name for the component. This name is globally used for power patching, with the container device's ID prepended. For example, Distrib1.Fuse1.
Scale X/Y/Z
2D Part X/Y
Rating
Displays the type and sensitivity of the overcurrent protector
Ampere
Sets the breaker amperage of the overcurrent protector
In
Select each in-socket connection from the list of Available options. Enter text in the search box to filter the list. Selected options are listed under Connected.
Out
Select each out-socket connection from the list of Available options. Enter text in the search box to filter the list. Selected options are listed under Connected.
Click Exit Symbol to return to the drawing. The component does not generate Power Information fields on the Object Info palette.
Placing an output component
Mode
Tool
Tool set
Electrical Output
An output component enables a device to transfer power.
When an output component is placed in a custom electrical device symbol, it generates an Output field on the Object Info palette of the device. When power patching the device, this output can be connected to another device's input; multiple connections can be made.
The output component can also be power patched from its Object Info palette. Each socket of the output component can be connected to an input socket or an overcurrent protector out-socket; multiple connections can be made. See Power patching from the Object Info palette and Concept: Power schematics.
To place an output component in a symbol definition:
Parameter
Description
Rotation
Name
Enter a name for the component. This name is globally used for power patching, with the container device's ID prepended. For example, Breakout1.Output1.
Scale X/Y/Z
2D Part X/Y
Connector
Sockets
Placing a consumer component
Mode
Tool
Tool set
Consumer
A consumer component defines a device as a power consumer.
When a consumer component is placed in a custom electrical device symbol, it generates an input field on the Object Info palette of the device. When power patching the device, this input can be connected to another device's output; a single connection can be made. See Power patching from the Object Info palette and Concept: Power schematics.
The consumer component cannot be power patched from its Object Info palette.
To place a consumer component in a symbol definition:
Parameter
Description
Rotation
Name
Enter a name for the component. This name is globally used for power patching, with the container device's ID prepended. For example, LightDev1.PowerColorScroller.
Scale X/Y/Z
2D Part X/Y
Connector
Power Consumption (W)
Sets the amount of power used by the device (its electrical load)
Power Factor
Sets the power factor for the device (this is the ratio of working power to apparent power; devices with a low power factor are less efficient)
Maximum/Minimum Voltage
Sets the minimum and maximum voltage at which the device can operate
Tracing a power source to its origin
Any object that participates in the power system, including both native consumer devices such as lighting devices and objects to which an input or consumer power component has been added, can have have its power traced back to the original source. When an object participates in the power system, a Power Information section is added to the Object Info palette.
To track the power source of a selected object:
Select an object that participates in the power system.
In the Object Info palette's Power Information section, click Select Power Source.
The object's immediate power source is selected in the drawing area, and becomes active in the Object Info palette. If that object isn't the origin of the power, Select Power Source is available for it as well.
Continue to click Select Power Source for sequential objects until you trace back to the origin.
Cables and power planning
Editing symbol definitions
Placing distributors
Lighting device properties
