Editing LED walls
Editing LED wall geometry
Command |
Workspace: Path |
Edit LED Wall Shape |
LED wall context menu |
Certain parameters of an LED wall depend on its Wall Mode. For example, an aspect wall has linked height and width, so changing one changes the other to maintain the aspect ratio. Supports, trim height, offsets, panel selection, and other settings may also restrict editing.
To edit the LED wall geometry:
Do one of the following:
Right-click on the LED wall and select the context command.
When there are no panels in the wall, simply double-click on the wall to activate the Reshape tool.
Select the wall and then click the Reshape tool.
Adjust the wall length or height by dragging to move the handles. When there are panel symbols, the tool snaps to potential spots based on the size of the panel symbols, and panels are added if needed. It may take some time to generate and auto number the new panels in the wall.
If you've made custom changes to the wall (for example, swapped out a different size panel or different panel symbol), editing it will discard the changes since the wall and its panels are regenerated.
It's possible to edit the LED wall to create very complex shapes, but then it may no longer work properly with rigging tools or with Braceworks calculations (Braceworks required).
Lengthening a freeform LED wall
Editing LED wall panels
Command |
Workspace: Path |
Edit LED Wall Panels |
Panels are automatically placed by the LED Wall tool based on the preferences. After placement, an individual panel can be edited.
To edit panels:
Select the context command, or double-click on an LED wall to access the panels in object editing mode.
Select the panel to edit; the parameters display in the Object Info palette.
Parameter |
Description |
Symbol Name |
The currently selected symbol displays; select a different panel resource from the Resource Selector if desired. If the new panel is a different size from the previous symbol, a warning displays, and you may need to adjust the LED wall mode, size, or height. |
Panel Short Name |
Specifies a shortened panel name |
Location/Position/ Wall/Section |
Adds information which can be placed on the drawing or used for reporting; some of these parameters are defined by the LED wall |
Unit |
Indicates the panel number (or the position along the associated rigging object) |
Power and Signal Details |
Provides information from the LED wall; these parameters are editable |
Panel Specifications |
Displays the panel's specifications based on the current settings |
Load Information |
A panel is considered a point load in Braceworks calculations. Load information is used for Braceworks calculations and reports (Braceworks required). |
Include in calculations (Braceworks required) |
Includes the LED wall panel in Braceworks calculations; deselect to exclude the object from participating in structural calculations |
Load Group Name |
The load category is always Video for LED wall objects/ panels |
Load ID |
Enter a unique ID for the load for informational use in reports |
Load Name |
Identifies the object in load calculations |
Weight |
Enter the total weight of the object |
Position |
Displays the name of an associated rigging object, if the LED wall object is attached. |
Exit object editing mode to return to the drawing. The wall is redrawn based on the panel changes.
Advanced users can create custom LED wall panels. A 3D-only symbol is required (hybrid is not allowed), and it must have the Video LED Wall Panel record attached. You can draw your own 3D panel, set its parameters, create a 3D symbol, and attach the record to the symbol definition. Alternatively, an existing hybrid panel symbol, copied from an LED wall in object editing mode, can be converted to a 3D symbol; copy the symbol, exit object editing mode, and then paste the symbol into the drawing in a 3D view and set its parameters. Select the symbol, and then select Modify > Convert > Convert to Group. Select the Convert all sub-objects option in the Convert to Group Options dialog box. With the group selected, choose Modify > Create Symbol to create a 3D symbol from the group. Attach the Video LED Wall Panel record to the new symbol definition from the Data tab of the Object Info palette; see Attaching record formats to symbols, objects, and materials.
Editing LED wall accessories
Support accessories are automatically placed by the LED Wall tool when you add top or bottom support accessories. After placement, an individual accessory can be edited.
To edit accessories:
Double-click on an LED wall to open the LED wall in object editing mode.
Select the accessory to edit; the parameters display in the Object Info palette.
Parameter |
Description |
Symbol Name |
The currently selected symbol displays; select a different accessory resource from the Resource Selector if desired |
Accessory Short Name |
Specifies a shortened accessory name |
Unit |
Indicates the accessory number (or the position along the associated rigging object) |
Load Information |
An accessory is considered a point load in Braceworks calculations. Load information is used for Braceworks calculations and reports (Braceworks required). |
Includes the LED wall accessory in Braceworks calculations; deselect to exclude the object from participating in structural calculations |
Load Group Name |
The load category is always Video for LED wall objects/panels /accessories |
Load ID |
Load Name |
Weight |
Position |
