SpotlightBridle preferences
Command
Workspace: Path
Bridle Preferences
Design Suite: Entertainment > Spotlight Settings
Spotlight: Spotlight > Spotlight Settings
Set the bridle preferences prior to inserting bridles in the drawing. Setting up default parameters ensures that all subsequently placed bridles have at least one dimension in common, to facilitate planning and assembly. Specify the default dimensions and parts, class settings, and whether to insert data tags automatically, and on which parts. Optionally, enable the use of structural members as house rigging points.
Bridle preferences can also be edited by clicking Preferences from the Tool bar when the Bridle tool is selected or from the Object Info palette by clicking Edit Bridle Preferences after the bridle is inserted.
To set the bridle preferences:
Select the command (alternatively, click Preferences from the Tool bar or Edit Bridle Preferences from the Object Info palette).
The Bridle Preferences dialog box opens.
Parameter
Description
Use Style
From the Resource Selector, double-click a resource to activate it, or click Unstyled. If a styled object is converted to unstyled, the current values are retained, but all parameters are set to By Instance to allow editing.
If a bridle style is edited and no longer meets the constraints, an alert dialog box opens to convert the bridles to unstyled or cancel the style edit. Convert the bridle to unstyled to change the constraints of the style. Specific alert dialog boxes open when the reason for the invalid constraint is known, to guide you to fix the situation.
General
General Settings
Use structural member as house rigging point
Enables bridle objects created in Auto Insertion mode to snap to structural members
Default Parts
Default Shackle
Select the default shackle
Default STAC Chain
Select the default STAC chain. Alternatively, choose <Use Shackle> to insert the default shackle instead of the STAC chain.
Add STAC chain at
Select the leg(s) to which the STAC chain is added
STAC chain on top of a leg
Inserts STAC chain at the top of the bridle leg. If this option is deselected, the STAC chain is inserted at the bottom of the leg.
Down Leg
Build down leg using
Select either a bridle part or hoist for the down leg.
When Hoist is selected, click the Resource Selector to select the default hoist symbol. If the available chain length is shorter than the required down leg length, bridle parts are added automatically to fill the missing length.
Constraints
Bridle Constraints
Select the default constraints that determine how bridles are created
Min/Max bridle leg angle
Creates bridles with the specified minimum and maximum leg angle between the bridle leg and the horizontal plane
Min/Max bridle leg length
Creates bridles with at least one leg of the specified minimum and maximum length
Min/Max bridle down leg length
Creates bridles with the specified minimum and maximum down leg length
Min/Max apex height
Creates bridles with the specified minimum and maximum apex height
Bridle part
Creates bridles with one leg using only the selected part
Data Tags
Data tags are placed offset from the tagged bridle part, at the same elevation; tags are created in the default class specified, if any, for the tag style.
If you select a data tag that does not exist in the file, the Preferences dialog box opens automatically when you use the Bridle tool, to select and import a data tag.
If you select a data tag that is incompatible with the bridle part, an alert opens. You can continue to use the data tag; however, the data displayed might not be correct for the part.
Insert data tag for bridle
Inserts a data tag on the insertion point when a bridle is inserted; select the data tag style from the Resource Selector
Insert data tag for leg
Inserts a data tag on the leg center when a bridle is inserted; select the data tag style from the Resource Selector
Insert data tag for down leg
When the down leg is a bridle, inserts a data tag; select the data tag style from the Resource Selector
Insert data tag for hoist
When the down leg is a hoist, inserts a data tag; select the data tag style from the Resource Selector
Classes
Sets the default classes for the various parts of the bridle. This allows portions of the bridle to be set to visible, grayed, or invisible.
Data tag classes are set by the data tag.
Use the standard class, select a class from the list of classes present in the drawing, or create a new class. Select <Rigging-Bridle> to place the bridle element in the same class as the bridle.
Class Prefix: Specifies an optional default root class naming standard for all bridle parts; click Assign Default Classes With Prefix to begin all bridle class names with the prefix, so that they are sorted together.
Assign Default Classes With Prefix: Sets the class names for all bridle elements to the standard, using the Class Prefix if there is one.
Bridle elements: For each portion of the bridle, specifies the class name standard; the class names shown here are applied to the elements.
Save as default
Saves the current settings in the dialog box as the default for this and future documents. If deselected, the current settings are saved only for the active file.
Managing bridle parts
Inserting bridles
Bridle properties
Adjusting the bridle configuration
Creating structural members
Adding data tags and labels
