Design SuiteImporting IFC files
Command
Path
Import IFC
File > Import
An IFC project, including one that contains multiple buildings or large information sets, can be imported into a Vectorworks file. The units of the imported file are determined by the Vectorworks file. The presentation layers or CAD layers from an imported IFC file are assigned to Vectorworks classes. Each IFC building story is assigned to a Vectorworks story. IFC phases can be mapped into existing Vectorworks phases; before importing, ensure the needed phases are added to the Vectorworks file. The georeferenced information from the IFC file can be used to automatically georeference the Vectorworks file and import the geometry correctly into it.
Stories, elements, property sets, and (for IFC4 only) quantity sets, in the IFC file can be filtered during the import, to remove irrelevant objects and unnecessary data. Filtering an import can significantly lower the file size, making both the import process and subsequent collaboration more efficient.
Create a reference to the original IFC file if the original file may change, and you want to keep the imported pages up to date. See "IFC references" below for more information about referencing.
To continue working in Vectorworks while importing IFC files, use the Vectorworks Cloud to process the files. (For more information, see Vectorworks Cloud Services and the online help for Vectorworks Cloud Services at https://cloud.vectorworks.net/portal/help/.) You can begin the process from Vectorworks or from the web portal. The converted files can then be downloaded to your local computer. Processing on the Vectorworks Cloud is available only with a subscription.
To import an IFC file:
Select the command. Alternatively, click the file to import and drag it into an open Vectorworks file.
Select the .ifc, .ifczip, or .ifcxml file to open, and click Open.
The Select IFC Stories and Elements dialog box opens.
At the top of the dialog box, select whether to process the IFC file on your local computer, or on the Vectorworks Cloud (subscription required).
Select the specific data to import. Choose whether to filter the view by stories, elements, or property sets. Click the column to the left of a row to include or exclude it during the import. A row with a check mark will be included; a row with no mark will be excluded. A row with a dash contains a combination of items to include and exclude.
Stories: Lists all IFC elements in the file by story. You can exclude a story and all its associated elements from the import, or click the disclosure arrow and select which elements within the story to exclude.
Elements: Lists all IFC elements in the file. You can exclude all elements of a certain type from the import, regardless of story.
Property sets: Lists all IFC standard, custom, and (for IFC4 only) quantity, property sets in the file. You can exclude an entire category of property sets from the import, or click the disclosure arrow and select which property sets within the category to exclude.
To customize the mapping of IFC presentation layers to Vectorworks classes, IFC stories to Vectorworks stories, and IFC phasing statuses to Vectorworks phases, click Class, Story and Phase Mapping. See Mapping to classes, stories, and phases.
At the bottom of the Select IFC Stories and Elements dialog box, georeferencing and file referencing options are available.
Parameter
Description
Georeferencing
When the IFC file to import contains georeferenced geometry, specify how to set the coordinate system. See Specifying document georeferencing.
Use the document's coordinate system
Imports and projects the geometry using the coordinate system settings that were already set for the document.
Use the IFC file's coordinate system
Uses the coordinate system from the imported file; select Set the document's coordinate system to match
If selecting a different coordinate system for the import, select this option to keep the layers and document using the same coordinate system.
Reference
References the original IFC file (master file), so that the imported IFC objects can be updated when the master file changes.
If the IFC file is processed on the Vectorworks Cloud, this option is not available.
Absolute path
Stores the absolute file path of the master file. Select this option when the location of the master file will not change in the future, or if the master file is on another volume.
Path relative to current document
Stores the file path of the master file relative to the target Vectorworks file; this option is available only if the master file is on the same volume as the Vectorworks file. Select this option if the target file and the master file may be moved to another volume in the future.
If you're using server-based project sharing, and the master file is not on the same volume as the Project Sharing Server, you'll be prompted to upload the file to the server's project folder.
The Source File path displays either an absolute or relative path, depending on the selection.
Save referenced cache to disk
Saves copies of the referenced IFC objects in the target Vectorworks file; if deselected, the target file is smaller, and the IFC objects are automatically updated when the target file is opened
Automatically update reference during file open
Updates the IFC objects from the master file each time this target file is opened, if the IFC objects are out of date
Click OK to start the import.
For the IFC file processed on your local computer, if the file has syntax errors that prevent import, an alert displays. When the import is complete, a list of the items that were successfully imported displays. Details about errors such as geometry problems or missing references are also listed. Click Save Report to save the report to a text file.
For the IFC file processed on the Vectorworks Cloud, the progress of the import is displayed in Cloud Status on the View bar and in the Cloud Job Status dialog box. Once the file has been processed, you can open the Vectorworks file from the cloud, locate the synced file on your system, or download it to your computer.
Displaying IFC files processed on the Vectorworks Cloud
To display cloud-processed files on your local computer, do one of the following:
From Cloud Status on the View bar, click View Jobs; the Cloud Job Status dialog box opens. Navigate to the file, click the disclosure arrow to expand the list, and then click Show in Finder (Mac) or Show in File Explorer (Windows) next to the file you want to display.
Select Cloud > Open Vectorworks Cloud Services Folder, and then open the IFC Imports folder.
For more information, see Monitoring the status of jobs processed on the Vectorworks Cloud.
By default, the IFC presentation layers and stories are imported into Vectorworks with a simple "IFC-" prefix added to the existing name. If desired, you can customize the prefix, or you can create a detailed mapping to assign each imported item to a specific class or story in the Vectorworks file. Likewise, you can map IFC phasing statuses to the phases needed for the Vectorworks project.
During the import process, click the Class, Story and Phase Mapping button to open the IFC Import Class, Story and Phase Mapping dialog box.
This dialog box has specialized functions to select and edit its list items; see List box functionality and List filters and search boxes.
Parameter
Description
Classes/Stories Settings
Lists saved mapping sets that can be used during import. The saved sets for classes and stories are maintained separately; the sets available depend on whether the Classes Mapping or Stories Mapping tab is selected.
See Using saved sets to save and apply saved settings.
Classes Mapping
Specifies how presentation layer names in the IFC file will be mapped to Vectorworks class names
Use prefix
Creates class names for imported elements by adding the specified Classes Prefix to the IFC presentation layer name. If desired, use dashes to create a hierarchical structure. Elements that have no presentation layer are assigned to the class "<classes prefix>None."
Use detailed mapping
Creates class names according to the Criteria-Based Mappings you specify. If none of the criteria apply to an imported element, a class is assigned according to the element's IFC presentation layer, as listed in the Fixed Mappings.
Add/Edit
Opens the IFC Import - Criteria Mapping dialog box to specify criteria for assigning imported elements to classes. To build the criteria statement, click each column of row 1 and select from the options available, or enter a field value. Click Add to add rows as needed. The criteria rows are tested and executed in order during import.
For example, to assign all internal doors to the same class, the criteria statement might look like this:
IFC Entity is IfcDoor AND Pset_DoorCommon.IsExternal is not TRUE
Click OK to close the dialog box, and the criteria statement displays in the mapping list. Then click the Vectorworks Class column and select an existing class from the list, or select New to open the New Class dialog box and create or import a class (see Creating classes).
Remove
Removes the selected row from the mapping criteria
Fixed Mappings
These mappings are used when an imported element doesn't match any of the criteria-based mappings. To map a layer, click the Vectorworks Class column and select an existing class from the list, or select New to open the New Class dialog box and create or import a class (see Creating classes). If the value is <Unchanged>, the IFC presentation layer name is used (or "None" if the element has no presentation layer).
Stories Mapping
Specifies how story names in the IFC file will be mapped to Vectorworks story names
Use prefix
Creates story names for imported elements by adding the specified Stories Prefix to the IFC story name. Elements that have no story are assigned to the story "<stories prefix>No Story."
To map an IFC story, click the Vectorworks Story column and select an existing story from the list, or select New to open the New Story dialog box (see Creating and managing stories). If the value is <Unchanged>, the IFC story name is used. If desired, enter an Elevation Offset to apply to the original IFC story elevation.
Phases Mapping
Specifies how phasing statuses in the IFC file will be mapped to existing Vectorworks phases. You can change the phasing data for individual objects later in the Object Info palette; see Managing object phasing on the Object Info palette.
IFC phasing statuses were added in IFC4; earlier versions of IFC don't have this data.
Use default mapping
Maps IFC phases to Vectorworks phases. To map an IFC phase, click the Phase Created and Phase Removed columns and select an existing Vectorworks phase from the list. All objects with the same IFC phasing status are mapped to the same Vectorworks phase.
Maps imported objects to Vectorworks phases according to the Criteria-Based Mappings you specify. If none of the criteria apply to an imported element, a phase is assigned according to the object's IFC Phasing Status, as listed in the Fixed Mappings.
Add/Edit
Opens the IFC Import - Criteria Mapping dialog box to specify criteria for assigning imported elements to phases. To build the criteria statement, click each column of row 1 and select from the options available, or enter a field value. Click Add to add rows as needed. The criteria rows are tested and executed in order during import.
For example, to assign all walls that contain "Shed" in the name to the same phase, the criteria statement might look like this:
ifcWall.Name contains Shed
Click OK to close the dialog box, and the criteria statement displays in the mapping list. Then click the Phase Created and Phase Removed columns and select existing Vectorworks phases from the lists.
Remove
Fixed Mappings
These mappings are used when an imported element doesn't match any of the criteria-based mappings. To map an IFC phase, click the Phase Created and Phase Removed columns and select an existing Vectorworks phase from the list.
IFC references
You can choose to reference an IFC file processed on your local computer, instead of importing the objects directly. This allows you to easily update the imported objects when the original file changes. It also prevents the creation of additional classes, layers, and resources.
Create the reference during the import process, or create a new reference from the Organization dialog box. By default, the IFC file is imported as an IFC - Referenced object, which is actually a design layer viewport on one layer. Optionally, you can choose the Layer import setting in the Organization dialog box to import each story as a referenced design layer instead.
See Concept: Workgroups and referencing for more information about creating and using references.
If the reference was imported as a design layer viewport, you can edit the viewport as follows (also see Modifying viewports):
From the Object Info palette, edit the classes and layers shown in the viewport.
Right-click on the viewport and select the Edit Crop command to edit the viewport crop.
Concept: IFC overview
Assigning IFC data to objects
Exporting IFC projects
Simplifying mesh objects
