LandmarkPlant shadow settings
To create custom plant shadow settings for a plant style or a plant instance:
On the plant settings Appearance pane, select Show shadow and Custom. Click Custom to open the Plant Shadow Settings dialog box and set the shadow settings.
Parameter
Description
Offset
Enter a value for the shadow offset and select the offset unit. Factor of plant height calculates the offset based on the object’s height and the offset value.
Angle
Set the shadow angle by entering a value between -180° to 180° or by using the slider. 0° is straight up.
Fill Style
Select a fill style for the shadow
Color/Resource/Class
Depending on the fill style selected, select a fill color, resource (hatch, image, gradient, tile), or class for the shadow
Opacity
Set the shadow opacity by entering a value between 0 and 100% or by using the slider
Use Class Opacity
Uses the class’s opacity setting (see Setting class properties)
Show Shadow Under Canopy
Displays the plant shadows under the plant canopy, when the canopy is transparent (the fill opacity of the 2D plant symbol is set to less than 100%)
Preview
Dynamically previews the plant shadow appearance
Plant settings: Appearance pane
