Design SuiteStair settings
These settings are available in the following locations:
Stair Preferences dialog box (creating an object)
Stair Settings dialog box (editing an object)
Object Info palette (editing an object)
From the Stair Preferences or Stair Settings dialog box, you can save the current stair settings as a symbol for reuse elsewhere in the same file or other files. Additionally, the Stair Preferences dialog box has a Transfer tab, which allows you to transfer specific settings to another stair.
The preferences are grouped into several tabs of related parameters. Select each tab and specify the parameters.
Stair settings: General tab
Stair settings: Geometry tab
Stair settings: 2D Graphics tab
Stair settings: Construction tab
Stair settings: Railings tab
Stair settings: Graphic Attributes tab
Transferring stair properties
