Editing data legends
To edit a data legend style, see Editing plug-in object styles.
To edit one or more data legend objects:
To access all editing options, select the object and edit the settings from the Object Info palette. For a styled object, you can use the Style list options to replace the style or convert the object to be unstyled if necessary.
To edit the layout, do one of the following:
Click Edit Cell Layout or Edit Title Layout from the Object Info palette
Right-click the object and select Edit Cell Layout or Edit Title Layout
Right-click the object and select Edit (or double-click the object); from the Select Edit Method dialog box, select the option to edit the cell or title layout
To recalculate data legends after editing, do one of the following:
Select one or more legends and click Recalculate from the Object Info palette
Right-click one or more selected legends and select Recalculate Selected Data Legends
Right-click a legend and select Recalculate All Data Legends
