Design SuiteAdding accessories to a door and window assembly
Tool
Tool set
Lintel
Sill
Stool
Trim
Shutter
Assembly Edit
In an assembly layout's object editing mode (see Editing a door and window assembly layout), the Assembly Edit palette offers several tools to to fit accessories to the assembly's frame segments. These accessories are designed specifically to work within door and window assemblies, not as separate objects.
Mullions are added using the Edit Assembly tool's Edit Frames and Mullions mode; see Editing objects in a door and window assembly.
Accessories can't be attached to a vertical segment located at a corner. Lintels, sills, stools, and trim that are attached to segments adjacent to a corner are always mitered at the corner, even when a corner post is used.
To fit an accessory to an assembly frame segment:
Select the tool.
Do one of the following:
Click [Object] Style on the Tool bar to select a resource from the Resource Selector.
Click Preferences to open the object preferences dialog box and specify the tool’s default parameters.
The parameters can be edited later from the Object Info palette; see Editing objects in a door and window assembly.
Move the cursor over the assembly.
Parts of the frame that support the accessory type highlight as you move over them.
Click (Shift-click for multiple selection) to select parts of the frame to add the accessory to, and press Enter, or click the check mark button on the Tool bar.
A single object spans across contiguous segments, and separate objects are placed on non-contiguous segments.
Settings for each accessory object are listed below. Only unstyled objects or parameters set by instance can be edited. Parameters available only on the Object Info palette for all accessory objects are shown in a table at the bottom.
These settings are available in the following locations:
[Object] Preferences dialog box (creating an object)
[Object] dialog box (editing an object)
Object Info palette (editing an object)
[Object] Style dialog box (creating or editing a style)
Lintel settings
Lintels can attach to one or more contiguous frame segments and fit their shape to the segments as one continuous object. Lintels are placed at the center of the frame depth.
Parameter
Description
Use Style
From the Resource Selector, double-click a resource to activate it, or click Unstyled. If a styled object is converted to unstyled, the current values are retained, but all parameters are set to By Instance to allow editing.
By Style/Instance
A graphic indicates whether each parameter is set to By Style and given a fixed value or set to By Instance and editable in the dialog box. An object style may have a combination of both settings, to balance the need for consistency and flexibility.
By Style/Instance settings are established by the style and cannot be changed from the settings dialog box.
To edit the object style, see Editing plug-in object styles; editing the style modifies all plug-in objects in the file that use the style.
General
Interior/Exterior Protrusion
Enter the interior and exterior lintel protrusion from the interior/exterior face of the frame
Thickness
Enter the lintel thickness
Left End Condition/Right End Condition
For each end, select whether to define an angle using the parameters below or to wrap the lintel along the frame segment adjacent to the lintel's end
Angle
For an angled end, enter the angle from the perpendicular at the end of the object path
Set angle parallel to adjacent frame segment
For an angled end, sets the angle parallel to the adjacent frame segment; this overrides any Angle value entered
Extension
For an angled end, optionally enter a distance to extend the lintel past the end of its path, as viewed from the exterior side
Wrap Distance
For a wrapped end, enter the distance to wrap the lintel along the frame segment
Use left end conditions for right
Sets the parameters for the right end to match those for the left end
Attributes
2D Attributes
Sets the Top/Plan visibility and attributes for the object when cut.
To control appearance and visibility, select a class from the list of classes present in the drawing, or create a new class. Select <Lintel Class> to place the attributes in the same class as the lintel object.
Set custom pen and fill attributes, or select an option to control them by object (from the Attributes palette), by class, or select None.
3D Attributes
Two By Style columns indicate whether the object's material is set by style or instance, and whether the class and texture are set by style or instance.
Select a material from the Resource Selector.
To control appearance and visibility, select a class from the list of classes present in the drawing, or create a new class. Select <Lintel Class> to place the part in the same class as the lintel object.
Select a texture from the Resource Selector, or click one of the buttons to use no texture, to use the class texture, or, if the material texture was previously overridden, to revert to the material's texture.
Sill settings
Sills can attach to one or more contiguous frame segments and fit their shape to the segments as one continuous object. Sills can only be placed to the exterior side of a frame.
Parameter
Description
Use Style
By Style/Instance
General
Sill Type
Select the sill type, and specify the alignment and measurements; sill alignment and measurement options depend on the Sill Type selected.
These options apply only to parts of the sill that don't meet wall closures
Angle
Enter the angle from the perpendicular at the end of the object path, as viewed from the exterior side
Sets the angle parallel to the adjacent frame segment and overrides any Angle value entered
Extension
Optionally enter a distance to extend the sill past the wall closure extents, when used, or the assembly frame, as viewed from the exterior side
Attributes
2D Attributes
To control appearance and visibility, select a class from the list of classes present in the drawing, or create a new class. Select <Sill Class> to place the attributes in the same class as the sill object.
3D Attributes
To control appearance and visibility, select a class from the list of classes present in the drawing, or create a new class. Select <Sill Class> to place the part in the same class as the sill object.
Stool settings
Stools can attach to one or more contiguous frame segments and fit their shape to the segments as one continuous object. Stools can only be placed to the interior side of a frame.
Parameter
Description
Use Style
By Style/Instance
General
Align
Select the stool's vertical alignment
Vertical Offset
Enter the vertical offset from the selected alignment location
(1) Lip
Enter the thickness for the stool's lip
(2) Nosing
Enter the dimension for the stool's nose
(3) Left/Right Extension
Sets the distance the stool extends past the wall closure extents, when used, or the assembly frame
Attributes
2D Attributes
To control appearance and visibility, select a class from the list of classes present in the drawing, or create a new class. Select <Stool Class> to place the attributes in the same class as the stool object.
3D Attributes
To control appearance and visibility, select a class from the list of classes present in the drawing, or create a new class. Select <Stool Class> to place the part in the same class as the stool object.
Trim settings
Trim objects attach to the inner edge of one or more contiguous segments of an assembly frame, with a user-defined offset. Exterior trim is placed on the exterior face of the assembly frame, and interior trim is placed on the interior face of the assembly frame, or of the interior face of the wall when using frame extensions.
Parameter
Description
Use Style
By Style/Instance
General
Side
Select whether the trim piece is on the exterior or interior side of the assembly
Width/Depth
Enter the trim's width/depth
Offset from Frame Edge
Enter the offset, if any, between the inner edge of the trim and the inner edge of the frame it's attached to
Start Condition/End Condition
These options do not apply when the the trim's path is a closed shape or the trim end fits to a wall closure
Angle
Extension
Optionally enter a distance to extend the trim past the end of its path
Use start conditions for end
Sets the parameters for the end to match those for the start
Attributes
2D Attributes
To control appearance and visibility, select a class from the list of classes present in the drawing, or create a new class. Select <Trim Class> to place the attributes in the same class as the trim object.
3D Attributes
To control appearance and visibility, select a class from the list of classes present in the drawing, or create a new class. Select <Trim Class> to place the part in the same class as the trim object.
Shutter settings
Shutters attach to the outer edge of vertical segments of an assembly frame, with a user-defined offset. They can be placed on the exterior and/or interior face of the wall the assembly is inserted into.
Parameter
Description
Use Style
By Style/Instance
General
Side
Select whether the shutter is on the exterior or interior wall face
Width
Enter the width
Shutter Frame Depth
Enter the depth of the shutter's frame
Offset from Frame
Enter the offset from the assembly frame
Shutter Type
Select whether to create a panel frame based on the parameters below or a custom shutter, using the symbol selected below
Top Shape
Select whether the top of the panel shutter is square or mirrors the shape of the adjacent top frame segment
Panel Frame Width
Enter the width of the panel shutter's stiles and rails
Number of Panels
Enter the number of panel divisions
Custom Shutter Symbol
For a custom shutter, select the symbol to use
Attributes
2D Attributes
To control appearance and visibility, select a class from the list of classes present in the drawing, or create a new class. Select <Shutter Class> to place the attributes in the same class as the shutter object.
3D Attributes
To control appearance and visibility, select a class from the list of classes present in the drawing, or create a new class. Select <Shutter Class> to place the part in the same class as the shutter object.
Assembly accessory settings: Object Info palette
All door and window frame assembly accessory objects share parameters that can be edited only from the Object Info palette.
Parameter
Description
Style
Replace, remove, or edit the current style, or create a new plug-in object style for this object; see Changing plug-in object styles from the Object Info palette.
Editing a style changes all instances in the file that use the style.
Hide style parameters
Hides the parameters that are set by style; these can't be edited from the dialog box or the Object Info palette
Bounding
Displays the current number of bound frame segments. Select Pick Frame Segments to manually select/deselect frame segments to bind the object to. Currently bound segments are highlighted; click (or Shift-click) to add or remove segments. Only consecutive segments can be selected.
Settings
Opens the [Object] Settings dialog box
