Editing seating sections
Command |
Path |
Edit Boundary |
Context menu |
To change the boundary of the seating section:
Select the command.
The Object editing mode opens.
Edit the boundary vertices directly, and use other tools and commands including the Clip tool, the Trim tool, and the commands for Editing 2D object surfaces.
When you exit the object editing mode, select whether to refill the seating section when the boundary changes are made, or discard the changes.
Alternatively, use the Reshape tool to reshape the boundary (see Reshaping objects).
Parameters can be edited directly in the Object Info palette or from the Seating Section Settings dialog box; see Seating section settings.
Custom editing individual seats
Command |
Path |
Edit Seating |
Context menu |
To make final custom edits to individual seats or sets of seats:
Right-click on the seating section and select the command.
Alternatively, double-click on the seating section object, or click Edit Seating from the Object Info palette.
The Object editing mode opens. You can add or delete seats, change the angle of individual seats, or change the size of the floor.
When you exit the object editing mode, select whether to modify the boundary when the seating changes are made, or discard the changes.
Custom renumbering selected seats
Command |
Path |
Number Seats |
Context menu |
To custom renumber only selected seats within the seating section:
The Number Seats dialog box opens.
Specify the new seat and row number parameters.
Select individual seats in the order you wish to number them, and then click in an empty part of the drawing to end numbering.
