SpotlightInserting curtains and borders
Mode
Tool
Workspace: Tool set
Modes for Creating polylines
Soft Goods
Design Suite: Detailing
Spotlight: Event
The Soft Goods tool creates a curved or straight stage curtain or truss border. To draw a curtain, either use the Soft Goods tool, or create a closed 2D shape and then select the Create Objects from Shapes command (see Creating objects from shapes).
To display hanging points for soft goods objects, select Load classes in the Braceworks preferences and select the load classes for point and distributed loads (see Braceworks preferences).
Mode
Description
Polyline creation options
Selects the method for drawing the object's path polyline; see Creating polylines
Soft Goods Style
Opens the Resource Selector to select a resource for placement; double-click a resource to activate it
Preferences
Sets the default parameters that are used for each new curtain or truss border
To create a curtain or border:
Click the tool and mode.
The Corner Vertex or Point on Arc modes are recommended. For more information on the polyline drawing modes, see Creating polylines.
Do one of the following:
Click Soft Goods Style on the Tool bar to select a resource from the Resource Selector.
Click Preferences to open the object properties dialog box and specify the tool's default parameters; select either Curtain or Border from the Function list.
The parameters can be edited later from the Object Info palette. Some information from parameters can also be placed on the drawing using the Text Options.
Parameter
Description
Style
Replace, remove, or edit the current style, or create a new plug-in object style for this object.
Editing a style changes all instances in the file that use the style.
Hide style parameters
(Object Info palette only)
Hides the parameters that are set by style; these cannot be edited from the dialog box or Object Info palette
Function
Select either Curtain or Border (for pipe-and-drape assembles, see Inserting pipe-and-drape assemblies)
Adjustable Length
Specifies the length of a straight curtain or border
Height
Indicates the height of the curtain or border
Height Relative To
Specifies whether the height is relative to the top trim or bottom trim; if the height is changed, the selected trim reference is maintained
Top Trim
Displays the height at the top of the curtain or border, taking into account the height of the curtain and its elevation
Bottom Trim
Displays the height of the bottom of the curtain or border (the distance from the floor)
Show centerline
In Top/Plan view, displays the curtain center line or the border reference line
Show Markers
Places an indicator at the start, end, or both ends of the curtain
Supports
Add pipe
Draws a pipe with the curtain; the length of the pipe is the same as that of the curtain
Color
Displays the support pipe color or texture specified on the 3D Options dialog box, Hardware pane
Add track
Draws the curtain track
Width
Sets the width of the curtain track
Color
Displays the track color or texture specified on the 3D Options dialog box, Hardware pane
Show Traveler Pull
Shows the traveler pull on the left or right of the track, or hides the traveler pull
Center Overlap
If Open From is set to Center, enter the overlap
Add solenoids
Adds curtain release solenoids
Ends Inset
Indicates the distance from the ends of the curtain where the first solenoid is placed
Target Spacing
Enter the desired spacing between the solenoids
Actual Spacing
Displays the resulting solenoid spacing
Total Solenoid Count
Displays the total number of solenoids placed
Open From
Select whether the curtain has an opening, and its position; for a center opening, specify the Center Overlap
Width
When a curtain opening has been selected, specifies the width of the opening
Show ghost curtain
Displays the open section of the curtain with dotted lines in Top/Plan view
Traveler
When a curtain opening has been selected, adds the weight from the curtain opening
Reverse side
For borders, switches the curtain to the other side of the center reference line
Running Length
For curved and/or multiple segment curtains, shows the total curtain length
Stock Drape Width
Specifies the width of an individual drape panel
Minimum Overlap
Indicates the total distance of curtain overlap for adjacent drape panels
Vertical Tied Fullness %
Sets the overlap percentage at each curtain tie, and affects the Total Drape Count
Total Drape Count
Displays the number of drape panels required based on the specified stock drape width
Show drape breaks
Places markers where each drape ends and the next one starts
Show overlap
Indicates where the drapes overlap
Drape Clips
Enter data about drape clips, if needed
Sandbags
Enter data about sandbags, if needed
Simple 2D
Simplifies the Top/Plan view of the curtain or border, showing it as a line
Simple 3D
Simplifies the 3D view of the curtain or border, showing it as a flat surface
Pleat Width (Visual Only)
Indicates the distance between pleats
Pleat Depth (Visual Only)
Indicates the depth of the curtain pleats
Flip pleats (visual only)
Switches the positive and negative portions of the pleats
Adjust Starting
For borders, offsets the starting point of the border
Adjust Ending
For borders, offsets the ending point of the border
3D Options
Opens the 3D Options dialog box, for setting the appearance of the curtain in 3D; see Setting soft goods 3D display options
Current Drape Option
Displays the currently selected 3D curtain option from the 3D Options dialog box
Materials and Finishes
Main Material Type
Enter notes about the curtain/border main material (does not affect the curtain appearance)
Color
Enter notes about the main curtain/border color (does not affect the curtain appearance)
Raw Width
Displays the main material's raw width
Lining Material Type
Enter notes about the curtain/border lining material (does not affect the curtain appearance)
Raw Width
Displays the lining material's raw width
Top Finish
Select the finish for the top of the curtain or border
Spacing
Sets the spacing for tie, hook, or grommet finishes
Bottom Finish
Select the finish for the bottom of the curtain or border
Pipe Note
 When Bottom Finish includes a pipe, enter data about the pipe, if needed
Sides Finish
Select the finish for the sides of the curtain or border
Vertical Sewn Fullness %
Specifies the curtain or border vertical fullness information (does not affect curtain appearance)
Horizontal Sewn Fullness %
Specifies the curtain or border horizontal fullness information (does not affect curtain appearance)
Weights
The weight is calculated based on the soft goods height, length, materials, fullness, and attachment methods. Calculated weights are approximate and may vary based on specific manufacturer specifications; you should verify the final total weight. For users with a Braceworks license, calculated weights are considered as a distributed load by Braceworks.
The settings in this section and the Top Finish, Spacing, Bottom Finish, Side Finish, Vertical Sewn Fullness, Horizontal Sewn Fullness, Height, and the track options and length are used to calculate the overall length of the curtain/border.
Use raw specifications
Select to automatically update the weight when the height, length, raw materials and their weights, and/or attachment method is changed
Calculation Reference
When Use raw specifications is selected, select the measurement unit to use for weight calculation
Main Specified Raw
When Use raw specifications is selected, enter the weight of the main raw material, per the Calculation Reference selection
Lining Specified Raw
When Use raw specifications is selected, enter the weight of the lining raw material, per the Calculation Reference selection
Raw Materials Options
When Use raw specifications is selected, opens the Raw Materials Options dialog box to enter the weight of soft goods parts that change infrequently; see Raw materials options.
Raw materials options for the soft goods styles are controlled as a group. If Raw Materials Options is set by style, the dialog box is inaccessible and the settings cannot be changed for individual instances. If Raw Materials Options is set by instance, all settings can be changed.
Raw Total Weight
Displays the calculated weight based on the current soft goods settings
Raw Distributed Weight
Safety Margin %
Enter the acceptable safety margin for the weight calculation
Final Total Weight
When Use raw specifications is selected, displays the calculated weight based on the current soft goods settings. When Use raw specifications is deselected, enter a weight; the Final Distributed Weight is automatically calculated.
When Use raw specifications is selected, displays the calculated weight based on the current soft goods settings. When Use raw specifications is deselected, enter a weight; the Final Total Weight is automatically calculated based on this value and the length of the soft goods object.
Position
Displays the name of the associated rigging object, if the curtain or border is attached.
For methods to attach loads, see Making the attachment.
Location, Unit, Purpose, Container ID, Vendor, Cost, Note
Adds information which can be placed on the drawing or used for reporting
Text Options
Opens the Text Options dialog box, to enable the display and format the text of labels; see Formatting soft goods object labels
Default Text Positions
Text labels can be moved by dragging their control point; this option returns them to their default locations
Parts Classes
Opens the Parts Classes dialog box, to specify class naming for the various parts of the soft goods object. This allows parts of the soft goods to be set to visible, grayed, or invisible.
Use the standard class, select a class from the list of classes present in the drawing, or create a new class. Select <Soft Goods Class> to place the soft goods element in the same class as the soft goods object.
Class Prefix: Specifies an optional default root class naming standard for all soft goods parts; click Assign Default Classes With Prefix to begin all soft goods class names with the prefix, so that they are sorted together.
Assign Default Classes With Prefix: Sets the class names for all soft goods elements to the standard, using the Class Prefix if there is one.
Soft goods parts: For each part of the soft goods object, specifies the class name standard; the class names shown here are applied to the parts.
Parts classes for the soft goods styles are controlled as a group. If Parts Classes is set by style, the dialog box is inaccessible and the settings cannot be changed for individual instances. If Parts Classes is set by instance, all settings can be changed.
Update
Updates the object
Load Information
A soft goods object is considered to be a distributed load in Braceworks calculations; the curtain line needs to be parallel to the rigging object. Load information is used for Braceworks calculations and reports (Braceworks required).
Include in Calculations
Includes the soft goods object in Braceworks calculations; deselect to exclude the object from participating in structural calculations
Load Group Name
The load category is always Scenery for soft goods objects
Load ID
Enter a unique ID for the load for informational use in reports
Load Name
Identifies the object in load calculations
Distributed Weight
Enter the distributed weight of the soft goods object; changes here also affect the Total Weight value
Total Weight
Enter the total weight of the object
Position
Displays the name of the associated rigging object, if attached. Optionally, attach this object to a rigging object, or change the rigging object association, by entering the Position Name of the rigging object. Delete the name to break the association.
For other methods to attach loads, see Making the attachment.
Equipment Subparts
Lists the subparts that make up the object. These subparts are counted and reported separately in equipment and inventory lists.
The parameters must be selected for display for this type of object in Spotlight preferences: Inventory pane.
Equipment Virtual Parts
Virtual parts are associated with an object and are reported in equipment and inventory lists, but do not display in the drawing. After adding virtual parts, they are listed in the Object Info palette.
Edit Virtual Parts
Opens the Virtual Parts dialog box to add virtual parts to the object; see Managing virtual parts and independent virtual parts
Assign Sources
Opens the Assign Sources dialog box to assign the object and its subparts and virtual parts to an inventory source; see Assigning equipment to an inventory
Vertex Parameters
Edits the vertices of the path object that the curtain is based upon; see Editing vertex-based objects
Click to set the soft goods object's start point.
Click to set the end of the segment and the beginning of the next. Continue drawing segments in this manner until the curtain or border object is complete, and then double-click.
Once created, the soft goods object can be reshaped by double-clicking on it. The Reshape tool is automatically activated, to reshape the object directly in the drawing.
Optionally, create a style resource for the object (see Standard plug-in object styles without catalog options).
When Use raw specifications is selected for the soft goods object, specify the weights for certain curtain and border parts. These weights are considered for automatic weight calculations.
Parameter
Description
Select whether to enter values as distributed weights or total weights in the units indicated; the alternative distributed/total weight is automatically calculated based on the object's settings
Parts list
Only parts that are included in the soft goods object's current settings are available; unused parts are greyed, and the weight cannot be entered or used for calculation.
Parts include top pipe, bottom pipe, track, track rollers, chain, lead tape, rope ties, "S" hooks, snap hooks, twill ties, tensioning lines, webbing, hook and loop, and single solenoid (distributed weight only).
Inserting soft goods
Concept: Attaching loads to rigging objects
