Design SuiteSlab preferences
These settings are available in the following locations:
Slab Preferences dialog box (creating an object)
Object Info palette (limited settings, editing an object)
Slab Components dialog box (editing an object)
Slab Data dialog box (editing an object)
Edit Slab Style dialog box (creating or editing a style)
Slabs include the ability to define components, set slab attributes and drainage settings, and more.
Slab preferences: Overall
Click to show/hide the parametersClick to show/hide the parameters.
Parameter
Description
Slab Style
From the Resource Selector, double-click a resource to activate it, or click Unstyled. If a styled object is converted to unstyled, the current values are retained, but all parameters are set to By Instance to allow editing.
If a selected slab style's parameters are edited in the Slab Preferences dialog box, the slab style automatically changes to unstyled, indicating that the edited style must be saved as a new style to save changes (alternatively, the changes can be applied as an unstyled slab, and they are not saved).
Save Preferences as Slab Style
Saves the current preference settings as a new slab style. The Assign Name dialog box opens; enter a slab style name (see Creating slab styles).
A saved or selected slab style is saved as a resource in the file, and displays in the Resource Manager and in the Slab Style list on the Tool bar.
Slab preferences: Definition tab
These parameters are also available on the Slab Components dialog box, which is accessed from the Object Info palette.
Parameter
Description
Preview
Displays a sectioned preview of the slab structure, including any defined components. The top of the preview indicates the top part of the slab as it will be drawn.
Overall Thickness
Displays the thickness of the slab. The slab thickness is always determined by the thickness of its components; a slab always has one component by default.
Edit Slab Attributes
Opens the Slab Attributes dialog box, to specify the slab fill and pen settings; see Editing slab attributes
Datum
Select whether the datum is applied to the top or bottom of the designated component; the indicator in the Datum column updates accordingly. A datum is the reference point for elevation settings; for slabs, it is fixed vertically (it does not change with any changes to the slab thickness or definition). One of the slab components is designated as the datum component.
Drainage
Select whether the slab is of fixed thickness or has a tapered component to assist with drainage. Click in the Tapered column to designate the tapered component.
Components
Lists the components that form the structure of the slab, in order from top to bottom as displayed in the preview. To change the order of a component, click and drag within the # column.
If multiple components are selected, changing the order moves all selected components to the new location.
Datum
Click in the column to designate the datum component. An indicator in the column points towards the top or bottom, to show that the datum is placed on the top or the bottom of the component. To change the datum to be at the top or bottom, either click on the indicator to switch the placement, or click Top of component or Bottom of component in the Datum section of the dialog box.
The reference datum of the slab can be set to the active layer elevation value, or set to be bound by one of the story levels defined for the story or the story below it (Architect or Landmark required). By setting the slab datum to a level type, if the elevation of the associated story changes, the datum of the slab changes automatically to match.
Tapered
If Tapered component is selected in the Drainage section of the dialog box, click in the column to designate which component is tapered. The bottom surface of the designated component is flat, and the top surface is tapered to incorporate the drainage. All components above and below the tapered component are of uniform thickness to maintain the taper that the designated component brings to the overall slab.
Other Component Settings
The remaining columns in the component list display the current settings for the slab, from the Slab Component Settings dialog box.
New
Opens the Slab Component Settings dialog box to define the components of the slab; see Creating slab components for information on creating components
Edit
Opens the Slab Component Settings dialog box to edit the attributes of one or more selected components; changes are made to all selected components. Alternatively, to edit a single component, double-click the component to open the Slab Component Settings dialog box.
Duplicate
Duplicates one or more selected slab components; the duplicates are added to the component list right below the originally selected components
Delete
Deletes one or more selected slab components; the slab thickness is adjusted accordingly
Slab preferences: Insertion Options tab
Parameter
Description
Height
Datum LayerZRef
Sets the slab’s datum height to be defined by the layer elevation, or set it to be bound by one of the story levels defined for the story or the story below it (Architect or Landmark required). By setting the slab datum to a level type, if the elevation of the associated story changes, the datum of the slab changes automatically to match.
Datum Offset from Layer Z
Specifies the offset (positive or negative) of the slab’s datum component from the layer elevation (see Setting design layer properties)
Class
Specifies the default class for the slab
Drainage Settings
Click to open the Slab drainage settings dialog box
Energos
(Architect Required)
Slabs can participate in Energos energy analysis calculations (see Energos energy analysis module). Vectorworks Architect is required to conduct an energy analysis; however, energy-related parameters can be specified here for informational purposes.
Include in calculations
When selected, the slab is eligible to be included in energy calculations, depending on the energy analysis settings for layer/class, element inclusion, and so on
Energy Function
Select whether the slab is a floor slab or roof slab
Object Boundary Type
Only certain slabs participate in energy analysis calculations; select the type of slab.
The system list can be modified; see Specifying system sets. Editing the system parameters, or adding new ones, allows the exterior and interior RS (surface resistance) values to be specified. If the selected boundary slab calculations are not satisfactory, edit the system list to be extremely specific about the slab surface resistance parameters.
Advanced
For a finer level of detail about special boundary slabs, click Advanced. The Advanced Settings dialog box opens. If the slab is a special type of slab that should participate in energy calculations, select Special type and then select the Type from the list and specify its parameters.
Heated Basement or Underground Floor Slab: Specify the basement depth, and enter the R-Value/U-Value for the virtual walls that surround the slab below ground level.
Unheated Basement: Specify the basement depth and height of the walls above ground, and then enter the R-Value/U-Value for the virtual walls that surround the slab below ground level, and above ground level. Indicate the air change flow rate and the volume of the unheated space.
Suspended Floor: For crawl space slabs, enter the height and R-Value/U-Value of the crawl space walls (the walls around the suspended slab). Specify ventilation parameters for the crawl space, entering the size of ventilation openings, the wind velocity, and wind shield factor (low factor for urban areas, with values around 0.1 for rural areas exposed to wind).
Slab on Grade: For slabs at grade level, enter the perimeter insulation width and thickness, and indicate the properties of any conductivity insulation. If horizontal insulation is present, select the option.
Calculated R-Value/U-Value
Based on the location of the slab within the building (boundary type) and orientation of the heat flow (surface resistance values), the slab R-Value/U-Value is calculated and displayed. This value, along with the size of the slab, is critical for a correct assessment of the building envelope in energy calculations.
Override calculated R-Value/U-Value
Select this option to override the calculated R-Value/U-Value and enter a manual value for the slab instead in Manual R-Value or Manual U-Value
Slab preferences: Textures tab
The Object Info palette Render tab has additional texturing controls for existing objects; see Managing object textures from the Object Info palette and Textures on objects with components. Textures applied from the Object Info palette override the textures set here unless the texture is set by style.
Parameter
Description
Use component textures
Uses the textures defined for the slab components to texture the slab.
This option can also be selected for an existing slab from the Render tab of the Object Info palette.
Use object textures
Uses the textures defined below for the slab parts
Part
Select the part to apply a texture to
Revert to Overall
If a part was assigned a texture but it should inherit its texture from Overall instead, select the part and click Revert to Overall. The part moves back below the divider in the Part list, and (from Overall) displays as its texture name.
Texture
Applies the selected texture to the selected Part. Select a texture from the Resource Selector, or click one of the buttons to use no texture, or to use the class texture.
Textures can also be set from the Render tab of the Object Info palette. Textures applied from the Object Info palette override the textures set here.
Slab preferences: Data tab
Specify slab information. This information can be included in a slab style schedule. These parameters are optional; enter text only where desired. These parameters are also available on the Slab Data dialog box, which is accessed from the Object Info palette.
Slab preferences: Object Info palette
Edit the properties of a selected slab and its components from the Object Info palette. The fields in the Object Info palette are named similarly (but not always identically) to those in the Slab Preferences dialog box and roughly reflect the order in which settings are entered in the dialog box, for ease of editing.
The slab parameters are described above. Only the parameters that are different in the Object Info palette are described here.
Parameter
Description
Style
Displays the current slab style. You can convert the slab to unstyled or see Creating slab styles, Replacing slab styles from the Object Info palette, or Editing slab styles.
Bounding
Slab edges can be automatically bound by associated walls, they can be defined manually, or they can consist of some automatically bounded edges and some manually bound edges. See Concept: Automatically bounded and manual slab edges and Converting slab boundary associations.
Components
Opens the Slab Components dialog box. For unstyled slabs, edits the slab components; for styled slabs, edits only the texture settings (see Creating slab components).
Edge Offsets
Opens the Edge Offsets dialog box, for independently setting edge offsets (see Setting edge offsets)
Slab Data
Opens the Slab Data dialog box to specify slab information
Area
Displays the slab area
Creating slabs
Drawing slabs manually
Creating automatically bounded slabs from existing walls
Creating slabs with both automatically bounded and manual edges
Using slab styles
