Bridle preferences
Command |
Workspace: Path |
Bridle Preferences |
Design Suite: Entertainment > Spotlight Settings Spotlight: Spotlight > Spotlight Settings |
To set the bridle preferences, do one of the following:
Select the command
Click Preferences from the Tool bar when the Bridle tool is selected
Create or edit a bridle style (see Custom plug-in object styles without catalog options)
Click Edit Bridle Preferences from the Object Info palette after the bridle is inserted
The Bridle Preferences dialog box opens.
Setting the bridle preferences before inserting bridles in the drawing is recommended. Setting up default parameters ensures that all subsequently placed bridles have at least one dimension in common to facilitate planning and assembly. Specify the default dimensions and parts, class settings, and whether to insert data tags automatically, and on which parts. Optionally, enable the use of structural members as house rigging points.
Bridle preferences: Overall
Parameter |
Description |
Use Style |
From the Resource Selector, double-click a resource to activate it, or click Unstyled. If a styled object is converted to unstyled, the current values are retained, but all parameters are set to By Instance to allow editing. If a bridle style is edited and no longer meets the constraints, an alert dialog box opens to convert the bridles to unstyled or cancel the style edit. Convert the bridle to unstyled to change the constraints of the style. Specific alert dialog boxes open when the reason for the invalid constraint is known, to guide you to fix the situation. |
Save as default |
Saves the current settings in the dialog box as the default for this and future documents. If deselected, the current settings are saved only for the active file. |
Bridle preferences: General pane
Parameter |
Description |
General Settings |
Use structural member as house rigging point |
Enables bridle objects created in Auto Insertion mode to snap to structural members |
Default Parts |
Default Shackle |
Select the default shackle |
Default STAC Chain |
Select the default STAC chain. Alternatively, choose <Use Shackle> to insert the default shackle instead of the STAC chain. |
Add STAC chain at |
Select the leg(s) to which the STAC chain is added |
STAC chain on top of a leg |
Inserts STAC chain at the top of the bridle leg. If this option is deselected, the STAC chain is inserted at the bottom of the leg. |
Down Leg |
Build down leg using |
Select either a bridle part or hoist for the down leg. When Hoist is selected, click the Resource Selector to select the default hoist symbol. If the available chain length is shorter than the required down leg length, bridle parts are added automatically to fill the missing length. |
Bridle preferences: Constraints pane
Parameter |
Description |
Bridle Constraints |
Select the default constraints that determine how bridles are created |
Apply Leg Constraints to |
Select which bridle legs should be constrained by leg angle and/or leg length |
Min/Max bridle leg angle |
Creates bridles with the specified minimum and maximum leg angle between the bridle leg and the horizontal plane |
Min/Max bridle leg length |
Creates bridles with at least one leg of the specified minimum and maximum length |
Min/Max bridle down leg length |
Creates bridles with the specified minimum and maximum down leg length |
Min/Max apex height |
Creates bridles with the specified minimum and maximum apex height |
Bridle part |
Creates bridles with one leg using only the selected part |
Bridle preferences: Data Tags pane
Data tags are placed offset from the tagged bridle part, at the same elevation; tags are created in the default class specified, if any, for the tag style. If you select a data tag that does not exist in the file, the Preferences dialog box opens automatically when you use the Bridle tool, to select and import a data tag. If you select a data tag that is incompatible with the bridle part, an alert opens. You can continue to use the data tag; however, the data displayed might not be correct for the part.
Click to show/hide the parametersClick to show/hide the parameters.
Parameter |
Description |
Insert data tag for bridle |
Inserts a data tag on the insertion point when a bridle is inserted; select the data tag style from the Resource Selector |
Insert data tag for leg |
Inserts a data tag on the leg center when a bridle is inserted; select the data tag style from the Resource Selector |
Insert data tag for down leg |
When the down leg is a bridle, inserts a data tag; select the data tag style from the Resource Selector |
Insert data tag for hoist |
When the down leg is a hoist, inserts a data tag; select the data tag style from the Resource Selector |
Bridle preferences: Classes pane
Sets the default classes for the various parts of the bridle. This allows portions of the bridle to be set to visible, grayed, or invisible.
Data tag classes are set by the data tag.
Use the standard class, select a class from the list of classes present in the drawing, or create a new class. Select <Rigging-Bridle> to place the bridle element in the same class as the bridle.
Parameter |
Description |
Class Prefix |
Specifies an optional default root class naming standard for all bridle parts; click Assign Default Classes With Prefix to begin all bridle class names with the prefix, so that they are sorted together |
Assign Default Classes With Prefix |
Sets the class names for all bridle elements to the standard, using the Class Prefix if there is one |
Bridle elements |
For each portion of the bridle, specifies the class name standard; the class names shown here are applied to the elements |
Bridle preferences: Object Info palette
Edit the properties of a selected bridle from the Object Info palette. The fields in the Object Info palette are named similarly (but not always identically) to those in the Bridle Preferences dialog box and roughly reflect the order in which settings are entered in the dialog box, for ease of editing. The available leg length parameters depend on the bridle type.
The bridle parameters are described above. Only the parameters that are different in the Object Info palette are described here.
Parameter |
Description |
Text Style |
Select a text style from a library or the current file. To use the style defined for the object's class, select <Class Text Style>. To format the text using options on the Text menu, select <Un-Styled>. See Using text styles and Formatting text. To maintain proper size and arrow location, the measurement label may not use all the specified text style attributes. |
Style |
Replace, edit, or remove the current style, or (for unstyled objects only) create a new plug-in style (see Custom plug-in object styles without catalog options). Editing a style changes all instances in the file that use the style. |
Type |
Displays the bridle type |
Properties |
Name |
Enter a name for the bridle object, for identification and reporting purposes |
ID |
Enter a unique ID for the bridle object, for use in reports |
Location |
Specify the location of the bridle object, for use in reports |
Weight |
When the selected bridle has at least one part with a weight of 0 (zero), enter the total weight of the bridle. The total weight, applied at the bottom of each bridle leg, is the sum of the weight of all parts that form each bridle leg. |
Time |
Enter the time needed for bridle assembly |
Cost |
Enter the cost of bridle assembly |
Edit Bridle Preferences |
Opens the Bridle Preferences dialog box |
Bridle Configuration |
Opens the Bridle Configuration dialog box, to assign bridle parts manually; see Adjusting the bridle configuration |
Forces |
Allowable Force Leg __ / Allowable Force Down Leg |
Enter the maximum force that the bridle leg and down leg can support; this value automatically updates if the leg parts are changed |
Force Leg __ / Force Down Leg |
Displays the force applied to the bridle leg and down leg (Braceworks required for calculated value) |
Designated Length |
Displays the bridle dimensions based on the object insertion points |
Apex Height |
Displays the height of the apex point, where all bridle legs meet. If a new value is entered, the bridle object is updated. |
Down Leg Length |
Displays the down leg length, measured from the apex point to the bottom of the leg. If a new value is entered, the bridle object is updated. |
Replace Down Leg with Hoist |
Opens the Select Hoist dialog box, to replace the down leg with a hoist symbol. Select the symbol to insert. |
Trim Leg __ |
Displays the Z height of the bottom of the bridle leg. If a new value is entered, the bridle object is updated. |
Length Leg __ |
Displays the length of the bridle leg |
Angle Leg __ |
Displays the angle of the bridle leg |
Parts Length |
Displays the parameters of the bridle based on the assigned parts |
Show Parts Length |
Draws the bridle legs with the specified parts; the parts length may differ from the original design, depending on the available parts |
Simple 3D Parts |
Draws a simple 3D representation of the bridle |
Delta from Parts Length |
Displays the offset between the Designed Length and the actual Parts Length |
Parts Length Leg __ |
Displays the length of the bridle leg as built from the specified parts |
Assign Parts automatically |
Configures the bridle automatically from the best available parts. The list of available parts can be edited; see Managing bridle parts. |
Reference Point |
Reference Point |
Select the drawing origin to use as a location reference, or use a hoist origin as the reference |
X/Y |
Displays the X and Y coordinates of the bridle object relative to the selected origin |
Display |
Use default coloring |
Uses default coloring for the bridle connection points. Otherwise, set the color from the Attributes palette; see The Attributes palette. |
Equipment Subparts |
Lists the subparts that make up the object. These subparts are counted and reported separately in equipment and inventory lists. The parameters must be selected for display of this type of object in Spotlight preferences: Inventory pane. |
Equipment Virtual Parts |
Virtual parts are associated with an object and are reported in equipment and inventory lists, but do not display in the drawing. After adding virtual parts, they are listed in the Object Info palette. |
Edit Virtual Parts |
Opens the Virtual Parts dialog box to add virtual parts to the object; see Managing virtual parts and independent virtual parts |
Assign Sources |
Opens the Assign Sources dialog box to assign the object and its subparts and virtual parts to an inventory source; see Assigning equipment to an inventory |
