Importing PDF
Command
Path
Import PDF
File > Import
The Import PDF command allows a PDF file to be imported into a Vectorworks file, where each PDF page becomes an independent PDF Page object that can be incorporated into the drawing. If the original file may change, and you want to keep the imported pages up to date, create a reference to the original PDF file (Vectorworks Design Suite product required).
Alternatively, the Import from Morpholio Trace command lets you import a sketch created in Trace as a PDF page object; see Importing from Morpholio Trace and morpholioapps.com/userguide/trace/?how-to-export-to-scale.
To import a PDF file:
Select the command.
Alternatively, click the file to import and drag it into an open Vectorworks file.
Select the PDF file to be imported.
The Import PDF dialog box opens.
Parameter
Description
Import Range
Specifies which portion of the PDF file to import
Pages
Imports the specified range of pages from the PDF file
All Pages
Imports all pages in the PDF file
Reference
For Vectorwork Design Suite products, references the original PDF file (master file), so that the imported PDF pages can be updated when the master file changes. See Concept: Workgroups and referencing for more information.
Absolute path
Stores the absolute file path of the master file. Select this option when the location of the master file will not change in the future, or if the master file is on another volume.
Path relative to current document
Stores the file path of the master file relative to the target Vectorworks file; this option is available only if the master file is on the same volume as the Vectorworks file. Select this option if the target file and the master file may be moved to another volume in the future.
If you're using server-based project sharing, and the master file is not on the same volume as the Project Sharing Server, you'll be prompted to upload the file to the server's project folder.
Save referenced cache to disk
Saves copies of the referenced PDF pages in the target Vectorworks file; if deselected, the target file is smaller, and the PDF pages are automatically updated when the target file is opened
Automatically update reference during file open
Updates the PDF pages from the master file each time this target file is opened, if the PDF pages are out of date
PDF Settings
Snap to Geometry
If the PDF originated from an application that creates vector graphics, creates snappable geometry on import (see Concept: Drawing with snapping); this setting can be toggled in the Object Info palette.
If the PDF and drawing file are not the same scale, Resizing or scaling an imported PDF object may be needed before snapping the geometry to drawing objects.
Show Annotations
Displays annotations to the PDF object, if there are any, in the imported PDF Page object; this setting can be toggled in the Object Info palette
Each PDF file page becomes a separate PDF page or referenced PDF page in the Vectorworks file.
In Vectorworks Design Suite products, a referenced PDF file can be opened with the default application associated with this file type. To open a referenced PDF file, use one of the following methods:
Right-click the referenced PDF file in the Navigation palette, and select Open.
Select the referenced PDF file in the Navigation palette, and select Open from the Utility menu.
Editing imported PDF objects
