SpotlightCreating schematic views
Command
Workspace: Path
Create Schematic Views from Faces
Create Schematic Views from Top/Front
Create Schematic Views from View Direction
Design Suite: Entertainment > Visualization
Spotlight: Spotlight > Visualization
The Create Schematic View commands create dynamic 2D views of rigging objects and the attached loads. Create schematic views before or after you have finished designing in 3D. Schematic views are linked with the model, so applicable edits are transferred between the model objects and their schematic views; see Concept: Schematic views.
Select the command to match the desired result.
Create Schematic Views from Faces allows you to select the surfaces that generate the schematic views.
Create Schematic Views from Top/Front allows you to specify the top and front of the rigging; based on that directional alignment, more views can be generated.
Create Schematic Views from View Direction allows you to automatically generate schematic views based on the global orientation of the drawing.
To create schematic views:
Do one of the following:
To create a schematic view of a single rigging object, select the object.
To create individual schematic views of multiple rigging objects, select the objects.
To create a schematic view of a connected rigging system, select a rigging object in the system.
Select the command.
If you selected one of the first two commands, which involve clicking faces, the selected objects display with temporary faces that can be clicked upon.
If you selected Create Schematic Views from Faces, click at least one face. Each selected face creates a distinct instance of a schematic view. Click a face a second time to deselect it if necessary, or press the Backspace key (Mac) or Back key (Windows) to deselect the most recent face. When the desired faces are selected, double-click in the drawing, or click the green check mark in the Tool bar.
If you selected Create Schematic Views from Top/Front, indicate the two faces that represent the top and front faces of the rigging objects. Click a face a second time to deselect it if necessary. The two selected faces should make a 90 degree angle. Remaining added views (left, right, bottom, and back) are automatically determined based on the selected two. This method maintains consistent directional alignment across multiple schematic views.
If you selected Create Schematic Views from View Direction, the views (front, left, right, top, bottom, and back) can be automatically generated, based on the global orientation of the drawing. This method maintains consistent directional alignment across multiple schematic views.
The Create Schematic Views dialog box opens.
Depending on how you proceeded, views are added automatically to the list, views can be edited, and/or the list is ready for you to add views. Specify each view's properties and other settings as described in Schematic view settings.
If Place with mouse click was selected, click to specify the location to place the schematic view or views on the designated layer or layers. Otherwise, the views are automatically placed.
For a single rigging object, the schematic view is placed.
For multiple rigging objects, the first schematic in the list is placed, and then each one is placed next to it in turn.
For a connected rigging system, the schematic views of the rigging object that was selected is placed first, followed by the system objects connected to it.
If selected, a schematic view marker is automatically added near the original rigging object to indicate the view direction of the schematic. Load objects within the rigging system are represented as separate schematic loads, shifted (if an offset was specified) to show exactly where the attachment point is and its orientation. The schematic versions of lighting devices display with their selected label legends and are automatically dimensioned if set.
Schematic views created from faces
If the schematic rigging objects overlap, they are placed on top of each other according to the stacking order. Use offsets for the loads if needed.
In a schematic Front view of the circular truss system, the overlapping trusses are placed on top of each other for a realistic appearance
In the schematic view, lighting devices and other load objects can be added, removed, and repositioned; see Managing loads for more information.
Once the schematic view has been created, it can be updated if the original objects change. See Updating schematic views.
Concept: Rigging objects
Using standard views
