LandmarkEditing plant styles
Edits to the plant style immediately affect all plants in the drawing that use the style. Edits affect the copy of the plant style in the active file, not the master plant style in the main library.
To edit an existing plant style, do one of the following:
Select AEC > Landmark Style Manager (Design Suite workspace) or Landmark > Landmark Style Manager (Landmark workspace) to edit plant style parameters from the Landmark Style Manager.
On the Plant Preferences or Plant Settings dialog box, click Edit Style.
Click the Plant Style on the Tool bar to open the Select Plant Style dialog box. Select the plant style to edit, and click Edit Style.
Right-click on a plant instance; select Edit from the context menu, and then click Style to edit the plant style's parameters.
Select a plant instance, and from the Object Info palette's Style parameter, select Edit Style.
From the Resource Manager, right-click on the plant style, and select Edit Style from the context menu.
From the Edit Plant Style dialog box or Landmark Style Manager, set the plant style parameters and graphics as described in Plant settings and Landmark Style Manager.
To copy external data for the plant style parameters, see Copying external plant data.
Edit the by style and by instance settings as described in Custom plug-in object styles without catalog options.
To share edits with other users or other files, including saving them to the user and workgroup library folders, see Creating custom resource libraries and Exporting resources.
Plant settings
Editing plant style graphics
Replacing plant style graphics
