Spotlight preferences: Lighting Devices: Parameters pane
Command |
Workspace: Path |
Spotlight Preferences |
Design Suite: Entertainment > Spotlight Settings Spotlight: Spotlight > Spotlight Settings |
You can globally set the insertion angle of lighting devices, and set default display parameters for the label legend. This pane also specifies which lighting device parameters and parameter groups display on the Shape tab of the Object Info palette, and which parameters can be set independently for accessories and for the cells in multi-cell devices.
To set preferences for lighting devices:
Select the command.
The Spotlight Preferences dialog box opens. Click the Lighting Devices: Parameters pane.
Parameter |
Description |
Orientation |
Default Insertion Angle |
Specifies the default angle of the extension line when lighting devices are inserted. This is a global setting for this machine and user, not a document setting. A setting of 90 degrees extends the line from the front of the lighting device, and 0 degrees extends it from the right side of the lighting device. |
Automatically rotate 2D to focus point |
Orients the 2D geometry of every lighting device towards its focus point, when the lighting device has an assigned focus point object |
Label Legend |
Label Legend Container |
Controls the appearance of the label legend container. Use symbol attributes: Uses the container symbol definition to specify the attributes. Use lighting device attributes: Matches the attributes of the container to the attributes of the lighting device. Use label attributes: Matches the attributes of the container to the attributes of the label legend text within the container. |
Automatically flip front and back legend text |
Mirrors the label legend along the X axis of all lighting devices |
Automatically flip left and right legend text |
Mirrors the label legend along the Y axis of all lighting devices |
Insert lighting devices |
Inserts lighting devices either on or off. This can be changed later from the Light Information tab of the Lighting Device dialog box; see Editing lighting devices. |
Lighting Device Parameters |
The lighting device parameters and parameter groups that display on the Shape tab of the Object Info palette can be customized. The custom parameters apply to all lighting devices in the file, and parameter sets can be saved. The last selected saved set of parameters is in effect, even when creating a new file. New files created in Vectorworks Spotlight always default to the last saved parameter set. Default lighting device parameters cannot be deleted. |
Saved Settings Options |
See Using saved sets to save and apply saved settings; select <Default> to apply the standard set for the Vectorworks Spotlight program |
Parameter list |
Lists the parameters and parameter groups, in order, that will display on the Shape tab of the Object Info palette. Only items with a check mark in the Show in Shape Pane column display on the Object Info palette. To change the order of parameters and to add or remove parameters from a parameter group, click and drag within the # column. A check mark in the Multi-Cell or Accessory column means the parameter can be set independently for each cell in a multi-cell device or for each accessory. If there is no check mark in the Multi-Cell column, the cells use the parameter value from the main lighting device. If there is no check mark in the Accessory column, the accessories use the value from the associated lighting device or cell. This functionality is not available for all parameters; if you cannot put a checkmark in the Multi-Cell and/or the Accessory column, that parameter cannot be set independently for cells/accessories. If your file was created in a previous version of Vectorworks, any default parameters that were removed from the current version are listed here. Typically, these parameters have the same name as in the previous version; the exceptions are U Dimmer (listed here as User U Address) and Address (listed here as User Address). Any customized parameters keep their custom values but update their default values, such as Type, to match the current version. |
Opens the Edit Field dialog box, to add a custom parameter to the list. Enter the name of the new parameter, select its type, and set the default value, if any (see Creating record formats). To create a pop-up list of pre-defined parameter options, select the Type Pop-up and click Choices to open the Edit Choices dialog box. List the options, pressing Enter (Windows) or Return (Mac) to separate each item. |
Create Parameter Group |
Creates a new parameter group from the selected parameters that are not already in a group. Enter the name of the new group. For more information about parameter groups, see Widget groups. Select Edit to open the Edit Parameter Group dialog box and edit the selected parameter Group Name. |
Opens the Edit Field dialog box, to edit the selected parameter Name, Type, and Default value. Alternatively, edit these fields directly in the parameter list; see List box functionality. The Type can only be edited for User data parameters. |
Delete |
Deletes the currently selected custom parameter or group name from the list; parameters that are deleted from a parameter group are added back to the list in the former position of the deleted group |
Opens the Additional Default Records dialog box, to select additional records with default data for lighting devices. Only applicable records display. Select one or more record formats from those present in the file; a check mark in the Use column indicates that the default data in the record will be included. At insertion or replacement, the lighting device processes the additional record. If a match is found for a record field name, the default data from the record attached to the symbol applies to that field and displays in the Object Info palette. |
Save as default |
Saves the current settings for all panes in the dialog box as the default settings for this and future documents |
