Concept: Cut planes in Vectorworks
Difficulty level: Intermediate
A cut plane is where an imaginary horizontal slice is taken through a model to reveal the internal parts of objects. For example, a cut plane that slices through a wall reveals a cross-section of the wall’s components, which wouldn’t be visible from a simple elevation view. The location of a cut plane matters, because some objects in a drawing may exist only above or below (or before or beyond) the cut plane, rather than be broken by it. These objects may display differently depending on where they are sliced.
A cut view shows the model with its sliced cross-section. Vertical and horizontal section viewports are types of cut views. Since vertical and horizontal section viewports define their own cut plane, an object shown in those viewports is relative to the cut plane in each viewport. However, objects seen in Top/Plan view (or any Top/Plan view viewport) will always use the same graphics. Since some of these objects may typically be shown as cut or uncut below (or above) for floor plans, a cut plane height must be set for the object to determine how it’s seen in Top/Plan.
Managing cut planes
In Vectorworks, a coordinated system allows you to set a default cut plane for a design layer, which applies whenever you show a Top/Plan view of that layer and its objects. Design Suite users have options to control the individual cut planes of frequently used architectural objects including walls and objects that are inserted in walls, such as windows and doors.
Walls and some other objects such as structural members and auto hybrids can be set to use the design layer’s cut plane, and their cut plane automatically changes if the design layer's cut plane is changed. Alternatively, each of these objects can use an individual cut plane unrelated to the design layer. These settings are found in the standard wall, curtain wall, and structural member preferences/settings dialog boxes, and in the auto hybrid's 2D Appearance dialog box accessed from the Object Info palette.
Similarly, plug-in objects that are inserted into walls can be set to use the wall’s cut plane or to use an individual cut plane. In this way, these objects can inherit the design layer’s cut plane for consistency across objects, or can be customized in a view as needed. For symbols, these settings are in the Create Symbol and Symbol Options dialog boxes. For plug-in objects, they're in the Plug-in Object Style Options dialog box and Plug-in Object Options dialog boxes.
Example: Changing the design layer cut plane
In this example, all walls and auto hybrids are set to use the design layer cut plane. All symbols, plug-in objects, wall recesses and wall projections are set to use the wall's cut plane, and therefore to adopt the design layer cut plane the walls are using. Simply changing the height of the design layer cut plane in the Organization dialog box changes the Top/Plan appearance of all objects from the unwanted look on the left, where the cut plane is too low to properly show the wall projection cut outs and the windows, to the preferred look on the right.
Example: Using an object's cut plane
The design layer cut plane in the top graphic is at set to a height that awkwardly cuts this auto hybrid furniture unit and gives the wrong appearance. The auto hybrid can be set to use its own cut plane height to give it the desired appearance, as though it's entirely below the cut plane.
Example: Individualizing object cut plane settings
In the top floor plan of this example, all objects are set to use the design layer cut plane (some objects use the walls' cut planes, which are set to use the design layer's cut plane). However, some objects don't display as needed. For example, the window above the stair landing shows as clerestory without cutting through the wall, the wall under the stair doesn't show the door opening below the cut plane, and the auto hybrid furniture object shows as cut. In the bottom graphic, the window, door, and auto hybrid all use their own cut plane instead of the design layer's to display as needed.
Object attributes and cut planes
Object attributes can be set to display differently for objects that exist above or below the cut plane. Likewise, you can use object attributes to control the display of an object that passes through the cut plane but needs to display as though it is entirely above/below the cut plane, as is common for plumbing fixtures, cabinets, hanging lighting fixtures, and furniture. Windows and door and window assemblies have the option to display as clerestory when not in the cut plane.  For most architectural plug-in object types, these settings are found in the Graphic Attributes, Attributes, or 2D Visualization pane of the Preferences/Settings/Style dialog box.
The stair object always defines its own cut plane; it can't use the design layer cut plane. Here the cut plane is at the stair landing. The adjacent interior wall uses the design layer cut plane. Both objects are set to use different attributes at, above, and below the cut plane.
A: Portion of wall below the cut plane
B: Portion of wall that passes through the cut plane
C: Portion of wall above the cut plane
D: Stair below the cut plane
E: Stair above the cut plane
2D components and detail levels
You can define how 2D components display for plug-in objects and symbols when passing through cut planes in hidden line rendered section viewports. You can also use 2D components to set the detail levels at which objects display at different scales and in viewports according to their detail level setting. See the help section beginning with Concept: 2D components for symbol definitions and plug-in objects.
The cook top detail that displays well at High Detail Level (left) would overwhelm the viewer if it all showed at Low Detail Level (right), so the Top (and Bottom) Cut 2D component is edited to display what is needed at each level
Setting design layer properties
Standard wall preferences: Insertion Options tab
Curtain wall preferences: Insertion Options tab
Editing wall attributes
Creating symbol definitions
Additional plug-in object style and instance options
Creating wall projections
Creating wall recesses
Creating auto hybrid objects
Structural member settings: Attributes tab
Window settings: 2D Visualization pane
Door settings: 2D Visualization pane
Door and window assembly settings: 2D Visualization pane
