Design SuiteDoor settings
These settings are available in the following locations:
Door Preferences dialog box (creating an object)
Door Settings dialog box (editing an object)
Object Info palette (editing an object)
Door Style dialog box (creating or editing a style)
If a style is selected, only parameters set by instance can be edited (see Concept: Plug-in object styles). Parameters available only on the Object Info palette are listed at the bottom of the page.
You can create plug-in objects with a combination of parameters that are determined by the manufacturer’s catalog item, by style and/or by instance, and then optionally save them as a plug-in object style. Catalog parameters have a fixed value established by the manufacturer and cannot be edited by the user. Style parameters have a fixed value established by the style; instance parameters can be set independently for each instance of the object in the drawing (see Concept: Plug-in object styles).
Additional plug-in object settings for the class, the 2D component and cut plane display, and wall insertion are available; see Additional plug-in object style and instance options.
Door settings: Overall
Parameter
Description
Use Style
From the Resource Selector, double-click a resource to activate it, or click Unstyled. If a styled object is converted to unstyled, the current values are retained, but all parameters are set to By Instance to allow editing.
By Style/Instance/Catalog
A graphic indicates whether each parameter within the style is set to By Catalog and defined by the catalog item, set to By Style and given a fixed value by the user, or set to By Instance and editable in the dialog box. An object style may have a combination of all three of these settings, to balance the need for consistency and flexibility.
By Style/Instance/Catalog settings are established by the style and cannot be changed from the settings dialog box.
To edit the object style, see Editing plug-in object styles; editing the style modifies all plug-in objects in the file that use the style.
Select from Catalog
If the catalog item is set by instance, opens the Catalog dialog box for selecting catalog items for plug-in object styles (see Selecting catalog items for plug-in object styles). If a current catalog item is associated with the style, static text displays the item’s description.
The catalog item itself can be set to By Style (to ensure that all objects using that style use the same catalog item) or to By Instance (if, for example, different sizes of the otherwise identical object require different catalog items).
3D Preview
Dynamically displays a 3D preview of the door with the currently selected parameters; the door's exterior side faces the Front view
View
Select the standard view for the 3D preview of the door
Render
Select the render mode for the 3D preview of the door
Detail
Select the detail level for the 3D preview of the door
Top/Plan Preview
Dynamically displays a Top/Plan preview of the door with the currently selected parameters; the door's exterior side is toward the bottom
Detail
Select the detail level for the Top/Plan preview of the door
Door settings: General pane
Parameter
Description
Size Reference
Select the appropriate option to define the door width and height; the Size Reference selection automatically updates the Width and Height fields, but does not change the size of the door:
Leaf Size: this represents the door width and height that measures to the inside of the frame, excluding the frame, transom, and sidelights; this is the default setting for imperial units.
Unit Size: this represents the current overall door width and height that measures to the outside of the frame, including the frame, transom, and sidelights.
Rough Opening: this represents the current overall door width and height that measures to the outside of the frame, including the frame, transom, sidelights, and shim gap (for the Opening Configuration, the Size Reference is automatically changed to Rough Opening); this is the default setting for metric units.
Width/Height
The width/height of the door is measured based on the Size Reference selection:
Leaf size: width/height of the door leaf is measured at the inside of the frame.
Unit Size: width/height is measured at the outside of the frame.
Rough Opening: width/height measures the rough opening.
Use symbol geometry
Select Use symbol geometry. From the Resource Selector, double-click a symbol to apply it.
The symbol name displays and the preview is updated with the selected symbol.
When a symbol is selected, all fields pertaining to the door’s geometry are overridden by the symbol geometry; however, parametric values are still available for scheduling and reporting purposes only.
Top Shape
Select the shape of the top of the door, as viewed from the exterior side
Include transom
Adds a transom above the door; transom parameters are set from the Transom pane
Rise
Enter the distance between the start of the top shape to the top of the door (not applicable for Square and Round Top Shape)
Spring
Enter the distance traveled above the floor before the Top Shape begins
Insert Relative to
Specify whether the insertion point is relative to the exterior face, center, or interior of the frame.
Additional wall insertion options are available, as described in Additional plug-in object style and instance options.
Unit Offset Reference
When the unit is inserted into an assembly, displays the assembly's unit offset reference
Unit Offset
Enter the unit's offset relative to the unit offset reference location. A positive value offsets the door toward the exterior and a negative value offsets toward the interior.
Curtain wall door
Indicates that the door will be placed in a curtain wall, where its width and height are based on the surrounding frames where it is placed. A curtain wall door does not have as many available parameter options as a standard door. Configurations are limited to those that apply to curtain wall placement.
Create niche for Space objects
Creates niche geometry that space objects can include in their net boundary areas; see Space settings: Space Area pane
Interior Side
Select which side of the wall the door considers the interior side, for the purpose of defining handing- and location-related settings such as leaf, hinge, frame, and trim location and open direction. This relates to the door settings only and does not change the wall's direction; see Wall direction.
Configuration
Select the general door configuration. To create a simple opening in a wall for defining a door break without creating any geometry to represent the door, select the Opening option. Depending on the selection, a variety of door settings are enabled or disabled automatically, as described in the following sections.
Operation
Select the advanced operation for the Configuration. For sliding and swing doors, "O" represents a fixed door and "X" represents an operating door.
Additional parameters
The available parameters related to door leafs, hinge sides, locations, open/swing directions, and pivot offset depend on the selected Configuration and Operation. For parameters with left/right settings, those directions are as viewed from the exterior side.
Many of these parameters, along with Interior Side can be changed interactively in the drawing area; see Interactive handing of doors and windows.
Door settings: 2D Visualization pane
Parameter
Description
Indicators
Operation Direction Marker
Select the direction marker style to use when the operation direction is visible, or set it by class. Click Custom to add a custom marker style or Edit Marker List to edit the list of options; see Marker attributes.
The visibility of this marker can be controlled on the Detail Levels pane.
Pivot Location Indicator Size
Set the size of the pivot location indicator for pivot doors; the visibility of this indicator can be controlled on the Detail Levels pane
Centerline Indicator
Displays a perpendicular line centered on the door leaves in Top/Plan view; the visibility of this indicator can be controlled on the Detail Levels pane
Centerline Length
Set the size of the centerline
Include Marker
Includes a marker at the end of the line; choose the desired style from the marker list, or select Custom to create a custom marker. Select Edit Marker List to open the Edit Marker List dialog box; see Editing the marker list.
Center with larger leaf
For bipart swing doors with leaves of unequal size, centers the line on the larger leaf instead of the opening
Attributes list
Sets the Top/Plan visibility and attributes for the door parts. Select one or more rows, and click the applicable columns to select the desired settings.
To control appearance and visibility, select a class from the list of classes present in the drawing, or create a new class. Select <Door Class> to place the attributes in the same class as the door object.
Set custom pen and fill attributes, or select an option to control them by object (from the Attributes palette), by class, by material (where applicable), or select None.
Door settings: 3D Visualization pane
To set materials and classes for door parts, see the Materials and Classes pane, below. 3D Visualization options are not enabled for the Opening Configuration.
Parameter
Description
Show 3D open
Shows 3D doors as open at the specified Open Angle. Enter the angle; valid values are:
Barn, overhead, pocket, and sliding doors: 0°–100°
Double acting and double egress doors: 0°–180°
Folding doors: 0°–90°
Swing doors: -180°–180°
3D Hinge Direction Indicator
Displays lines representing the 3D hinge direction
Indicator Points Towards
Set the hinge direction indicator to point toward the hinge or toward the handle
Include pivot door pivot line
Shows a vertical line at the pivot location
Attributes list
Sets the 3D visibility and attributes for the door parts. Select one or more rows, and click the applicable columns to select the desired settings.
Door settings: Detail Levels pane
Vectorworks can automatically display the desired detail level based on the design layer’s scale; see Document preferences: Display tab. Different levels of detail can also display for different viewports. Once the door parts' detail levels are established, set each viewport to display the desired Detail Level when creating the viewport, or set this from the Object Info palette.
Vectorworks automatically produces door representations in low, medium, and high detail levels for display at different scales, but some door parts are left for you to determine.
Parameter
Description
2D Detail Levels
For each part, set whether/how it should display at each detail level. Use the Top/Plan Preview to view the settings at the desired detail level.
3D Detail Levels
For each part, set whether/how it should display at each detail level. Use the 3D Preview to view the settings at the desired detail level.
The Muntins list item controls the display for all muntins in the door (in leaf, sidelights, and transom).
Trim controls interior and exterior door trim.
Hardware controls the detail level for all hardware selected in the Hardware pane of this dialog box.
Door settings: ID Tag pane
The Data Tag tool provides more flexible options for tagging doors; see Adding data tags and labels.
Parameter
Description
Include on schedule
Includes this door's information in the door schedule; see Creating reports and Using preformatted reports
Show tag in 2D
Displays the ID tag in Top/Plan view
ID Prefix
Places a prefix before the label value
ID Label
Enter a label to identify the door
ID Suffix
Places a suffix after the label value
ID Class
To control visibility and, if Use ID class attributes is selected, appearance, select a class from the list of classes present in the drawing, or create a new class. Select <Door Class> to place the ID class attributes in the same class as the door object.
Uses the ID class attributes for the bubble line, leader line, and leader line marker
Keep ID horizontal
When selected, automatically rotates the ID so that it is horizontal
Bubble Shape
Select the ID tag bubble shape
Bubble Size
Enter the minimum bubble size (this value represents the bubble size times the layer scale; the bubble shape is maintained relative to the text inside it for ID bubble uniformity throughout the drawing file)
Bubble Line Attributes
Select the bubble line attributes and weight, or select Set Thickness to open the Set Thickness dialog box for creating a custom line thickness
Show leader
Draws a leader line from the ID tag to the door object
Line Attributes
Select the leader line attributes and weight, or select Set Thickness to open the Set Thickness dialog box for creating a custom line thickness
Include marker
Includes a marker for the ID leader line; choose the desired style from the marker list, or select Custom to create a custom marker. Select Edit Marker List to open the Edit Marker List dialog box; see Editing the marker list.
Show tag in 3D
Displays the ID tag in 3D views
Horizontal Offset
Enter the horizontal offset of the 3D ID tag relative to the bottom left corner of the rough opening when looking at the exterior side of the door (a positive value moves the tag inside the opening relative to the starting corner; a negative value moves the tag outside the opening relative to the starting corner).
The ID tag is offset slightly from the outside face of the door leaf. The size and shape of the text and bubble, if present, will match the plan settings, and the text will always be right reading from the outside of the wall. The bubble will scale with text scaling in viewports.
Vertical Offset
Enter the vertical offset of the 3D ID tag relative to the bottom left corner of the rough opening when looking at the exterior side of the door (a positive value moves the tag inside the opening relative to the starting corner; a negative value moves the tag outside the opening relative to the starting corner)
Door settings: Configuration: Barn Door pane
Barn Door options are enabled only for the Barn Configuration.
Parameter
Description
Leaf Size
Displays the width and height of each leaf, calculated from size parameters on the General pane and the Leaf Overlap
Leaf Overlap
Enter the amount the leaves will extend past the outside edge of the trim and each other, on the Sides (when the door is closed) and the Top of the door.
If there is no trim on the same side of the wall as the door panel, the leaves will extend past the outside edge of the frame by the specified dimension.
Leaf to Wall Clearance
Enter the distance between the wall surface and the face of the leaf
Leaf to Leaf Clearance
Enter the distance between bypassing leaves
Show Rail
Select whether to display the rail hardware, and in which 2D/3D views
Rail Type
Select the rail type
Rail Depth/Height
Enter the depth and height of the rail
Left/Right Side Extension
Enter the distance on the left/right the rail should extend beyond the width required to clear the door
Add door post of width
For a Box Rail Type, adds a door post; enter the post’s width
Show Rail Mounts
For Flat and Round Rail Type, select whether to display the rail mounts in 3D views
Distance from Rail Ends
Enter the distance the first and last mounts are inset from the rail ends
Maximum Spacing
Enter the maximum spacing between rail mounts
Bypass Bracket Type
For Bypass Operation, select whether to display the brackets, and the bracket type
Show Leaf Hangers
Select whether to display the leaf hangers in 3D views
Leaf Hanger Mounting
Select whether the hangers attach to the top or the front face of the leaf
Leaf Hanger Offset
Enter the distance between the edge of the leaf and the center of the door hanger
Hanger Length/Width
Enter the length and width of the door hanger
Roller Diameter
For Flat and Round Rail Type, enter the roller diameter
Door settings: Configuration: Folding pane
Folding door options are enabled only for the Folding Configuration.
Parameter
Description
Hang Position
For Multiple Operation, select how the leaves are hung from the track
Show leaves in both open and closed states
Shows both the open and closed representations of leaves in Top/Plan view. This option has no effect when the Open Angle is set to 0°.
Show in Overhead/Alt Path Class
When Show leaves in both open and closed states is selected, specify which Top/Plan representation to display with attributes of the Overhead/Alt Path class.
The Closed Leaves option always displays leaves as single lines.
Passage Leaves
For Multiple Operation, select which leaves to set as Passage Leaves. For both the Left and Right leaves, the Start leaf is closest to the frame, and the End leaf is farthest from the frame.
Show passage leaf swings
Displays passage leaf swings in Top/Plan view in the Overhead/Alt Path class
Door settings: Configuration: Pocket pane
Pocket door options are enabled only for the Pocket Configuration.
Parameter
Description
Leaf Size
Leaf Side Overlap
Sets the distance the door leaves overlap each other when closed
Use Stile Width
Sets the leaf side overlap to match the stile width of the leaf.
When this field is selected, Leaf Side Overlap is automatically completed and disabled.
Specifies the distance between the door leaves and the wall pocket
Use exposed pocket recess
Exposes the pocket cavity on one side of the wall
Recess Depth
Displays the distance between the door leaves
Auto-calculate
Automatically sets the recess depth as needed to contain the door leaves
Include recess finish
When Use exposed pocket recess is selected, adds a finish to the vertical surfaces of the pocket recess
Recess Finish Thickness
Sets the thickness of the pocket recess finish
Recess Finish Attributes
Specifies the class for the exposed pocket door recess finish:
Outer Wall Component: The recess finish acquires the attributes and texture of its adjacent wall component.
Pocket Door Recess Class: The recess finish acquires the attributes and texture set for the Pocket Door Recess class parameter on the Materials and Classes pane.
Door settings: Configuration: Sliding pane
Sliding door options are enabled only for the Sliding Configuration.
Parameter
Description
Leaf Size
Leaf Side Overlap
Use Stile Width
Door settings: Frame pane
Frame options are not enabled for the Opening Configuration or for curtain wall doors.
In Double Acting and Double Egress configurations, the leaves are mounted so that they are centered on the frame when they are closed.
Parameter
Description
Width
Enter the face width of the door frame (parallel to the wall)
Depth
Enter the depth of the door frame (perpendicular to the wall)
Use wall depth
Sets the frame depth to the overall wall depth
Auto-expand Depth for sliding and pocket configurations
Automatically increases the frame Depth as needed to receive sliding or pocket door leaves. The required frame depth is equal to the total depth of the leaves and their clearances.
Selecting this setting never decreases the frame depth specified by other settings.
Use frame extension
Select this field to specify a frame extension to fill any gap between the interior face of the frame and the interior face of the wall; enter the desired Frame Extension Width.
In 2D views, extensions use the Frame line types and weights; in 3D views, the extension fill color and/or textures and visibility are controlled by the Int. Frame class.
Shim Gaps
Sets the distance between the frame and the rough opening for each side of the door. Doors in a door and window assembly don't model shim gaps.
Use wall provided gaps
Sets the gaps on all four sides to those specified by the wall closure profile offsets, calculated with the door's Size Reference from the General pane; see Wall closure settings
Left/Right/Top/Bottom
When wall-provided gaps aren't used, enter the gap value for each of the four sides, or click the Link button to match the gap to the one above it
Masonry Module
Enter the masonry module dimension
Astragal Flange/Depth
Use these two dimensions to determine the size of the astragal flange or depth (enter zero to display without an astragal flange); enabled if Swing Configuration and Double Bi-part Operation are selected on the General pane
Door settings: Leaf pane
Leaf options are not enabled for the Opening Configuration.
Parameter
Description
Leaf
Select the desired leaf type
Thickness
Enter the thickness of the door slab
Gap Below Leaf
Enter the distance between the bottom of the leaf and the bottom of the frame or threshold.
When the Size Reference is set to Leaf Size, the leaf is moved in the Z direction to make room for the gap, and the height of the leaf is not automatically changed. This effectively changes the overall height of the door.
Solid
Include vision panels
Includes vision panels
Vision Panel Shape
Select the shape of the vision panel
Bottom Edge Offset
Enter an offset value, measured from the bottom of the leaf to the bottom of the lowest vision panel
Strike Edge Offset
Enter an offset value, measured from the strike edge of the leaf to the nearest edge of the vision panel.
With some of the more complex, multi-part door configurations, the offset is measured from different points to provide correct alignment of vision panels. Consult the 3D Preview to confirm the appearance.
Panel Height/Width
Enter the height/width of the individual vision panel.
Panel Width is enabled only for the rectangle and oval vision panel shapes. For square and round, the width is automatically set equal to the height.
Number of Panels
Enter the number of vision panels
Separation
For leaves with more than one vision panel, enter the vertical offset between panels
Set top panel height
For leaves with more than one vision panel, makes the top vision panel a different height than the other panels; specify the desired Top Panel Height
Glazing Thickness
Enter the glazing thickness for the vision panels
Glass
The Glass leaf type enables the options specific to glass doors on this pane, such as Muntin Style; it does not make the door leaves render as transparent glass. To make the glass render properly, apply a Glazing class on the Materials and Classes pane.
Top Rail Width
Enter the width of the top door rail
L/R Stile Width
Enter the width of the left and right stile
Bottom Rail Width
Enter the width of the bottom door rail
Muntin Style
Select the muntin style
Vertical/Horizontal Bars
Enter the number of vertical/horizontal muntin bars
Bar Width/Depth
Enter the muntin bar width/depth
Bar Offset
Enter the muntin bar offset for Prairie muntins
Glazing Thickness
Enter the glazing thickness for the glass leaf
Panel
Top Rail Width
L/R Stile Width
Bottom Rail Width
Vertical/Horizontal Panels
Enter the number of vertical/horizontal panels in the door
Mid Stile Width
Enter the width of any interim stiles
Makes the top door panel a different height than the other panels; specify the desired Panel Height
Single top panel
Draws only one panel across the top of the leaf, regardless of the number of panels below
Glazing in top panels
Inserts glazing in the top panel
Glazing Thickness
Enter the glazing thickness for glass in the top panel
Muntin Style
Bar Width/Depth
Bar Offset
Custom
Custom Leaf
Select the leaf type from the default content; see Concept: Resource libraries.
Custom leaves must be 3D-only symbols made from generic solids, saved in the default content location.
Door settings: Second Leaf pane
Second door leaf options are enabled only for doors with a two-leaf Configuration and leaves of unequal widths; the narrower pane is considered the second leaf.
Parameter
Description
Second Leaf
By default, bi-part doors make both leaves the same Leaf setting (Glass, Panel, or Custom), Width, and Open Angle, but these settings can be changed
Unequal leaf
For double egress doors and doors having a double bi-part Operation, inserts a door with leaves of unequal widths
Width Leaf 1/2
When Unequal leaf is selected, enter the width of the first door leaf; the width of the second door leaf is calculated automatically and displayed in the Width Leaf 2 value
Custom open angle
Displays the second leaf with a custom open angle for Top/Plan and 3D views. Enter the angle; valid values are:
Include hardware
Includes the hardware specified for the first leaf on the second leaf
Set second leaf as solid
Makes the second leaf solid; when deselected, the second leaf has the same Leaf setting as the first leaf
Vision Panels
Add vision panels
Adds vision panels to the second leaf; select whether to make the panels the same width as vision panels on the first leaf, or enter a custom width.
This option is available only when both leaves are solid and Include vision panels is selected for the first leaf.
Muntins
Adds muntins to the second leaf; select whether to use the same number of vertical bars as the first leaf, or enter a custom number.
This option is available when both leaves are glass or are paneled with Glazing in top panels selected for the first leaf.
Panels
Adds panels to the second leaf; select whether to use the same number of horizontal panels as the first leaf, or enter a custom number.
This option is available only when both leaves are paneled.
Custom Leaf
Select whether to use the same custom leaf symbol as for the first leaf, or select a different symbol from the default content.
This option is available only when both leaves are custom.
Door settings: Lights pane
Lights options are not enabled for the Opening Configuration or for curtain wall doors.
Parameter
Description
Sidelights
Include sidelights
Adds sidelights
Left/Right Width
Enter the left/right sidelight width
Sash Width/Depth
Enter the sidelight sash width/depth
Mullion Width/Depth
Enter the sidelight mullion width/depth
Use frame depth
Overrides the sidelight Mullion Depth with the frame depth.
When this field is selected, Mullion Depth is grayed.
Glazing Thickness
Enter the glazing thickness for the sidelights
Muntins
Include muntins
Adds muntins to the sidelights
Pattern
Select the sidelight muntin pattern
Enter the number of vertical/horizontal muntin bars for Colonial muntins
Bar Width/Depth
Enter the sidelight muntin bar width/depth
Bar Offset
Door settings: Threshold pane
Threshold options are not enabled for the Opening Configuration.
Parameter
Description
Include threshold
Includes a threshold
(1) Interior Depth/(2) Exterior Depth
Enter the interior and exterior threshold depth
(3) Overall Depth
Enter the overall threshold depth
(4) Offset
Enter how far to offset the threshold from the center of the door frame
(5) Thickness
Enter the threshold thickness
(6) Nosing
Enter the threshold nosing height
Z Offset
Enter the Z elevation of the threshold
Threshold under leaf
Limits the threshold to under the leaf; otherwise, to extend the threshold beyond the inside of the frame, deselect this and enter the desired exterior and interior extension values
Exterior Extension/Interior Extension
Enter the amount that the threshold extends beyond the wall closures on the exterior or interior sides of the wall (negative values are not permitted)
Door settings: Louvers pane
Louvers can be applied to doors with all Configurations except Opening and Cased Opening.
Parameter
Description
Replace with louvers for
Select which parts of the door to replace with louvers; if Leaf panels is selected, all panels in the door are replaced
Louver Type
Select the louver type
Preview
The preview displays a profile view of the selected Louver Type and the parts to be dimensioned
(1) Blade Spacing
Enter the distance on center between the blades
(2) Blade Angle
Enter the blade angle, measured positively from horizontal
(3) Blade Lip
Enter the visible lip of the blade; for jalousies, enter the thickness of the blade
(4) Louver Depth
Enter the depth of the louver assembly
Add louver frames in leaves
Adds frames around the louvers; enter the Depth and Width
Door settings: Transom pane
Transom options are not enabled for the Opening Configuration or for curtain wall doors.
Parameter
Description
Sash
Sash Width/Depth
Enter the transom sash width/depth
Sash Offset
Offsets the sash from the center of the frame. A positive value moves the sash toward the exterior of the door, and a negative value moves the sash toward the interior of the door.
Mullion
Mullion Width/Depth
Enter the transom mullion width/depth
Use frame depth
Overrides the transom Mullion Depth with the frame depth.
Muntins
Include muntins
Adds muntins to the transom
Pattern
Select the transom muntin pattern
Bar Width/Depth
Enter the transom muntin bar width/depth
Bar Offset
Glazing Thickness
Enter the glazing thickness for the transom
Door settings: Trim pane
Trim options are not enabled for the Opening Configuration or for curtain wall doors.
Parameter
Description
Include interior/exterior trim
Includes interior/exterior trim
Width/Depth
Enter the interior/exterior trim width and depth
Door settings: Lintel pane
Lintel options are not enabled for the Opening Configuration or for curtain wall doors.
Parameter
Description
Include lintel
Adds a lintel above the door or transom
Interior/Exterior Protrusion
Enter the interior and exterior lintel protrusion
(1) Thickness
Enter the lintel thickness
(2) Angle
Enter the lintel angle
(3) Drop
Enter the length of the lintel drop
Door settings: Hardware pane
Hardware options are not enabled for the Opening Configuration.
Parameter
Description
Include hardware
Adds hardware to the door object, to add detail for 3D presentations, and to track hardware requirements in a door schedule. If enabled, specify the edge offsets and select a set from the hardware list.
Strike Edge Offset
Specifies the horizontal offset of the door hardware; the offset is measured from the strike edge of the leaf to the center of the door hardware
Bottom Edge Offset
Specifies the vertical offset of the door hardware; the offset is measured from the bottom of the leaf to the center of the door hardware
Hardware list
Select a hardware set for the door
View Hardware
Opens a dialog box to view the parameters for the currently selected door hardware set
Manage Hardware
Opens a dialog box to customize the door hardware library; see Managing door hardware sets
Door settings: Kick Plates pane
Kick plate options are not enabled for the Opening Configuration or for curtain wall doors.
Parameter
Description
Interior/Exterior kick plate
Includes a kick plate on either side of the leaf
Height
Set the height of the kick plate.
While the height is variable, the kick plate’s distance from the right, left and bottom edges of the door is a fixed value of one inch/25.4 mm.
Class
To control visibility, select a class from the list of classes present in the drawing, or create a new class. Select <Door Class> to place the kick plate in the same class as the door object.
Door settings: Materials and Classes pane
Materials and classes can be set for individual door parts. If a material resource is used to define a part, the material typically provides the fill, texture, physical attributes, and construction information needed for drawings, renderings, and reports. The class controls the part's appearance and visibility. The visibility of the overall 3D door is controlled by the Class setting from the Object Info palette.
Parameter
Description
Door parts
Lists all parts that can be assigned an individual material, class, and texture. Some parts are divided into interior and exterior sides, that can be set separately. Two By Style columns indicate whether the part's material is set by style or instance, and whether the class and texture are set by style or instance.
Select one or more rows, and click in the applicable columns to do any of the following:
Select a material from the Resource Selector.
To control appearance and visibility, select a class from the list of classes present in the drawing, or create a new class. Select <Door Class> to place the part attributes in the same class as the door object.
Select a texture from the Resource Selector, or click one of the buttons to use no texture, to use the class texture, or, if the selected item's material texture was previously overridden, to revert to the material's texture.
The material, class, and/or texture of all selected parts are assigned.
For doors with an Opening Configuration, in a 3D view a no fill/no pen weight extrude completely fills the wall in place of the door; this extrude is placed in the Interior Frame class and is filtered out in IFC export operations. Change the class settings to control the visibility of the extrude.
The Pocket Door Recess class determines the Recess Finish Attributes when Pocket Door Recess Class is selected on the Configuration: Pocket pane.
ArchitectDoor settings: Energos pane
Doors play a critical role in energy analysis calculations. Energy is lost through any door glass, and when the door is opened, but energy is also gained by solar radiation through the door glass. Accurately determining the R-Value/U-Value and the shading factor is essential for the overall energy analysis.
Vectorworks Architect is required to conduct an energy analysis; however, energy-related parameters can be specified here for informational purposes.
Parameter
Description
Include in calculations
When selected, the door is eligible to be included in energy calculations, depending on the energy analysis settings for layer/class, element inclusion, and so on
R-Value/U-Value
Automatic Calculation
Based on the door type, the door R-Value/U-Value is calculated and displayed. This value, along with the door shading factors, is critical for a correct assessment of the building envelope in energy calculations.
Manual Input
Select this option to override the calculated R-Value/U-Value and enter a manual value for the door instead. For complex or detailed door designs, enter results from a third-party calculation here.
Door Type
Select the thermal quality of the frame and any door glazing. Sets can be created and edited; see Specifying system sets.
Shading
Select the level of shade for each type of shading near the door, or select Custom from any of the lists. The Edit Shading dialog box opens, to manually enter a percentage for when the door is in the shade.
General
Select the general shade conditions where the door is located
Surrounding
Specify surrounding shade conditions that might affect the amount of solar radiation reaching the door
Summer Shading
Specify special shade conditions that apply in during the summer months (for example, when nearby deciduous trees shade the door)
Additional Shading
Select any mechanical or passive shading mechanisms in place, or select Custom and enter a shading percentage in the Edit Shading dialog box
Summer Ventilation
Opens the Summer Ventilation Settings dialog box, for specifying summer ventilation options for when the door is typically open.
Type of usage: (ground floor, upper floor, night): Select the type of ventilation system usage, if any, for the door
Operable opening width: For windows in doors, indicates the width of the window opening gap for an operable window (which affects the amount of ventilation)
Door settings: Data pane
Certain data fields cannot be edited.
Parameter
Description
Field Name/Field Value
Data fields are listed under Field Name. Click the Field Value column to enter data for use in the door schedule, as needed.
Door settings: Object Info palette
If the door has been inserted as a plug-in object, most settings from the Door Settings dialog box display on the Object Info palette. If the door is a black symbol made from a door object, fields pertaining to door geometry do not display. See Concept: Vectorworks symbols. The fields in the Object Info palette are named similarly (but not always identically) to those in the Door Settings dialog box, and roughly reflect the order in which settings are entered in the dialog box, for ease of editing. Curtain wall doors have limited parameter options. For doors using object styles, the parameters that are set by style display for informational purposes but cannot be edited from the Door Settings dialog box or the Object Info palette.
To edit door parameters in the Door Settings dialog box, click Settings from the Object Info palette, double-click the door to open the Door Settings dialog box, or right-click on a door and select Edit from the context menu.
Most door parameters are described in in the settings panes above. Only the parameters that are different in the Object Info palette are described here.
Parameter
Description
Insert
For doors in a wall, specify where to insert the object relative to the wall, its core component, or its designated insert location
Offset
Enter the offset of the insert perpendicular to the wall's path
Flip
Click to flip the orientation of doors inserted in a wall; relevant parameters set by instance are changed to match the door's new orientation. See Interactive handing of doors and windows for a visual way to change door orientation and related parameters.
Set Position
For doors inserted in a wall, click to activate the Move by Points tool in Reference Point mode and move the door by a specified distance from a reference point
Wall Closure
For doors in a wall, opens the Wall Closure dialog box; see Wall closure settings.
See Additional plug-in object style and instance options for information on wall insertion options in the Plug-in Object Style Options dialog box or Plug-in Object Options dialog boxes.
Style
Replace, remove, or edit the current style, or create a new plug-in object style for this object; see Changing plug-in object styles from the Object Info palette.
Editing a style changes all instances in the file that use the style.
Select From Catalog
For a plug-in object style with the catalog item set by instance, click to select a catalog item; see Selecting catalog items for plug-in object styles
Hide style parameters
Hides the parameters that are set by style and by catalog; these cannot be edited from the dialog box or Object Info palette
List box functionality
Doors and Windows
Energos energy analysis module
Door terminology specific to the UK, Australia, and New Zealand
