Editing Walls
Wall Properties
Edit the properties of selected straight or round walls and their components, as well as curtain walls (Vectorworks Architect or Landmark required), in the Object Info palette. To change the wall attributes, use the Attributes palette. Certain parameters are available for standard walls or for curtain walls only. Settings on the Render tab (Renderworks required) are not available for curtain walls, since the textures of frames and panels are specified separately. Curtain walls use the Edit Curtain Wall tool to adjust the frames and panels.
Reshaping Walls
Removing Wall Breaks
Joining Walls
Inserting and Editing Symbols Within a Wall
Editing Curtain Walls
Creating Walls
Creating Curtain Walls
www.vectorworks.net
