The Issue
ManagerThe Issue Manager accesses and displays information about drawing issue, dates, and history on a sheet-by-sheet basis. It interacts with the sheet border object by allowing the user to control the sheet border title block data and issue information. (Sheet borders can either be placed with the Sheet Border tool in the Dims/Notes tool set—see Adding a Sheet Border—or created and placed by the Document Setup or Create Standard Viewports commands—see Document Setup and Standard Viewports.)
To use the Issue Manager:
Ensure that at least one sheet border with a title block is present in the drawing.
Select File > Issue Manager.
The Issue Manager dialog box opens.
The tabs and fields displayed depend on the title block inserted in the sheet border. Custom title blocks may not match the parameters or tabs shown here. The fields and tabs shown assume that an Arch-style title block is inserted.
Click the Project Data tab to configure the project information.
Leave a blank field to create an empty line in the title block.
The information on the Project tab applies to all sheet borders or title blocks in the set.
Enter the project information. If the project was created with the Create Standard Viewports command (Vectorworks Architect required), some of the information has been automatically entered.
Click the Sheet Data tab to configure information about individual sheet layers in the set.
Complete the information for each sheet in the drawing set to be issued. Toggle among other sheets in the drawing with the Next and Prev buttons.
If the project was set up with the Create Standard Viewports command (Vectorworks Architect required), some of the information has been automatically entered. For each sheet, specify sheet-specific information and indicate whether to include the sheet in the issue.
Click the Issue Data tab to specify information about the current issue.
Click OK.
The sheet border title blocks are updated for the selected sheets. If specified, the issue information is included in the title block.
Regardless of whether the title block contains fields for the issue data, the data is still written to a record attached to the sheet border, becoming a permanent part of the sheet border. If the title block changes later, the data can be displayed.
