Several different tables list the operating status of the Vectorworks Site Protection Server. You can view the RLM statistics (web server statistics), ISV statistics (vektorwrx statistics), and the current license usage statistics.
Access: Click Status from the main Server Administration screen. RLM server information and server statistics are displayed.
Description: Shows the overall operating time and communication status of the RLM server.
Access: Click Status from the main Server Administration screen to access the Status screen. From there, click vektorwrx from the Server Status column.
Description: The vektorwrx statistics show the load information of the ISV server. For more information, see ISV Server Status.
Access: Click Status from the main Server Administration screen to access the Status screen. From there, click vektorwrx from the License Usage column.
Alternatively, click Status from the main Server Administration screen to access the Status screen. In the License Pool area, click Usage in the Show License Usage column.
Description: As described in License Usage Status, currently used licenses are shown.
Parameter |
Description |
Product |
The name of the module |
Pool |
The pool number |
Ver |
The version number |
User |
Displays the user name |
host |
Displays the name of the host using the license |
PID |
Shows the product ID |
req ver |
The Vectorworks version that was requested by the client |
#lic |
Shows the number of licenses used by each user |
#res |
Shows the number of reserved licenses |
Out time |
Shows the start time for using the license |
In (hold) time |
Shows the scheduled day to return the license (for a borrowed license) |
Click to REMOVE |
Returns the license currently in use to the Vectorworks Site Protection Server. This operation is only available for licenses connected to the network. It does not work for borrowed licenses. If a Windows service is installed with the rlmdown command disabled, as described in Server Startup Options, then this button does not display. |
