Inserting Symbols with the Duplicate Symbol in Wall Tool
Use the Duplicate Symbol in Wall tool to easily place multiple copies of a symbol (or plug-in object) in a wall, such as doors or windows in an office building or electrical outlets along a wall.
Symbols can also be duplicated within walls with the Duplicate Array command (see Inserting Symbols in a Duplicate Array) and with the Move by Points tool (see Moving Symbols in Walls with the Move by Points Tool).
The Duplicate Symbol in Wall tool has two modes.
Mode
Description
Flip
Flips the symbol during placement (for example, changes the direction that a door opens)
Standard
Places the symbol using the orientation at creation
Preferences
Specifies symbol placement information
To place duplicate symbols in a wall:
  1. Click the Symbol Insertion tool from the Basic palette.
  2. If the desired symbol is in the current document, another open document, or in a document in Favorites, select the symbol definition from the Active Symbol Def list on the Tool bar. Select a file on the left to display thumbnails of the symbol definitions available in that location, and select the desired symbol definition.
  3. If the desired symbol is not available from the Active Symbol Def list, select the desired symbol from the Resource Browser, then Select Make Active from the Resources menu. If the Symbol Insertion tool is not active when the symbol is activated in the Resource Browser, making the symbol active automatically activates the tool.
    Alternatively, double-click the symbol in the Resource Browser to make the symbol active and automatically activate the Symbol Insertion tool.
    You can also activate a symbol already placed in the drawing with the Symbol Pick up mode of the Symbol Insertion tool (see Symbol Pick Up Mode).
    The symbol must have the Insert in Walls option enabled (see Creating New Symbols).
  4. Click the Duplicate Symbol in Wall tool from the appropriate tool set:
  5. ●    Fundamentals workspace: Walls tool set
    ●    Design Series workspaces: Building Shell tool set
  6. Select the placement mode from the Tool bar.
  7. This sets the symbol orientation. To place the symbol using the orientation in which it was created, click Standard mode. To flip the symbol when it is placed, click Flip mode.
  8. Click Preferences from the Tool bar.
  9. The Duplicate Symbol In Wall dialog box opens. Indicate how to place the symbols.
  10. Click OK.
  11. Click the wall to indicate where the first symbol should be inserted. A preview of the symbols are shown along the wall to aid in placement. If inserting the first symbol by an offset value, click anywhere on the wall and the first symbol preview displays at the proper offset distance.
  12. If spacing symbols by the next mouse click, move the cursor along the wall to set the spacing between symbols, and click again to insert the duplicate symbols. If spacing symbols by a specified distance, click again to insert the duplicate symbols. If a number of copies is specified, that number of symbols is automatically inserted.
Move the cursor to the opposite side of the wall to flip the symbol direction.
Moving Symbols in Walls with the Selection Tool
Nudging Symbols in Walls
Moving Symbols in Walls with the Move Command
Editing Symbols in Walls
vectorworks.net
