The Symbol Insertion tool is in the Basic palette.
Use the Symbol Insertion tool to place 2D, 3D, and hybrid symbols in the drawing. During insertion, a preview of the symbol is shown to aid in placement. Symbols can also be inserted by dragging them from the Resource Browser.
Each symbol has its own insertion point that controls how the symbol is placed into the drawing. The insertion point is specified during the symbol’s creation, and its location on the symbol is shown by crosshairs in the Edit Symbol window.
Hybrid symbols can only be inserted on a working plane that is parallel to the active layer plane. When inserting a hybrid symbol, if the working plane is not parallel to the active layer plane, the working plane is aligned with the active layer plane. (The working plane origin remains unchanged.)
Mode |
Description |
Standard Insertion |
Inserts the symbol based on its specified insertion point, or aligned according to one of the symbol alignment modes |
Offset Insertion |
Inserts the symbol in a wall according to an offset reference point |
Symbol Pick up |
Designates a symbol from the drawing as the active symbol |
Wall Insertion |
Toggles between inserting a symbol or plug-in object into a wall with wall breaks, and inserting a symbol or plug-in object near or on a wall without breaking it. To prevent all symbol and plug-in objects from inserting into walls, turn off Wall Insertion mode. When Wall Insertion mode is enabled, objects that have the Insert in Walls option enabled will insert into walls. |
Symbol Alignment Modes |
These alignment modes apply to Standard Insertion mode, and temporarily override the insertion point. These modes change the alignment of the insertion point along the X axis of the bounding box surrounding the symbol. Alternatively, keep the original point as the insertion point. |
Align Symbol Left |
Moves the insertion point to the left edge of the symbol’s bounding box, along the original X axis |
Align Symbol Center |
Moves the insertion point to the center of the symbol’s bounding box, along the original X axis |
Align Symbol Right |
Moves the insertion point to the right edge of the symbol’s bounding box, along the original X axis |
Align Actual Insertion Point |
Uses the symbol’s originally specified insertion point |
Active Symbol Def |
Selects a symbol definition for placement. The files and folders available in the current document, in other open documents, and in Favorites are listed on the left. Select a file to display thumbnails of the symbol definitions available in that location, and select the desired symbol definition. |
Click here for a video tip about this topic (Internet access required).
