Viewport Properties
Once it has been created, edit the viewport in the Object Info palette, or select Properties from the viewport’s context menu to open the Properties dialog box.
A viewport is assigned to the None class when it is created, and its visibility is controlled by the class settings when that class is not active.
Once a section viewport is created (Vectorworks Design Series required), you may need to add or remove items that display in the section view. To do so, first use the Convert to Lines, Convert to Polygons, or Convert to Group command to convert the viewport to another form. (This conversion results in a group of lines and other primitives; it is no longer a viewport and cannot be updated to reflect drawing changes.) The conversion will produce different results, depending on which command is used and on how the viewport is rendered at the time of the conversion.
Properties of Section Lines and Section-Elevation Markers
Detail-Callout Markers and Detail Callout Instances
Advanced Sheet Layer Viewport Properties
Advanced Design Layer Viewport Properties
Advanced Section Viewport Properties
Creating Sheet Layer Viewports
Creating Design Layer Viewports
Creating Section Viewports
Creating Detail Viewports
Modifying Viewports
Viewport Status
Updating Viewports
Layers Overview
vectorworks.net
