Removing Object Connections
The connection between an object and a database can be removed.
To remove object connections:
Select one or more objects. The objects should already be connected to a database.
Select Tools > Database > Remove Object Connection.
The database is disconnected from the object(s).
Single Object Connection
Multiple Object Connection
Editing Object Connections
Database Setup
Database Connection
Record Format Database Connection
Specifying Update Settings
Concept: Record Formats, Reports, and Schedules
Database-Vectorworks Communication
Was
this page helpful?
vectorworks.net
