The Camera Match object contains the photo, controls, and target reference for manipulation; it is inserted into the drawing by placing it in the sheet layer viewport while in Edit Annotation mode.
To place a Camera Match object:
Right-click (Windows) or Ctrl-click (Mac) on the sheet layer viewport and select Edit Annotations from the context menu. See Creating Annotations for Sheet Layer Viewports .
Select View > Camera Match > Place Camera Match Object.
The Camera Match Settings dialog box opens.
Select a photo from the current file, or click Import New Image to import a new photo image as described in Importing Image Files.
Select the Camera Match reference from the Reference Object list, and select the line style to use for the extension lines.
Click OK.
A Camera Match object is placed in the viewport annotation. The properties of the Camera Match object can be edited from the Object Info palette.
