Inserting a Straight TrussStraight truss parameters are illustrated by the following diagram.
To add a straight truss to the light plot:
Click the Straight Truss tool from the appropriate tool set.
● Spotlight or Braceworks workspace: Spotlight tool set
● Designer workspace: Detailing tool set
Click to place the object in the drawing, and click again to set the length and rotation.
Trusses are 2D/3D hybrid objects. Complex trusses can increase the time required to render the model in 3D.
A connection interval shorter than the defined interval length is displayed in red when Highlight is selected.
To use the truss as a hanging position, convert it to a hanging position object; see Creating a Hanging Position Object.
