Trimming and Clipping Objects
Trim Command
Use the Trim command to trim lines or walls where they intersect with another object.
To trim objects:
  1. If necessary, position the trimming object over the object to be trimmed.
  2. Select the trimming object.
  3. Select Modify > Trim.
  4. Click the object to be trimmed.
The trim command is executed and the pieces can be moved independently.
Trim Tool
Clip Tool
